Go to Post Unconventional isn't necessarily innovation. - AdamHeard [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:13
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Modifications
Posted by Bill Beatty.
Other on team #71, Team Hammond, from Team Hammond.
Posted on 10/24/2000 8:47 AM MST
Is it OK to modify the robot after the competition has started? ie: having two separate chassis and moving the motors and controls over during lunch. Of course all variations would be within the rules.
Bill B
#0047 (ChiefDelphi)
Re: Modifications
Posted by Raul.   [PICTURE: SAME | NEW | HELP]
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 10/24/2000 11:05 AM MST
In Reply to: Modifications posted by Bill Beatty on 10/24/2000 8:47 AM MST:
Bill,
I can tell from your question that you already have the unique elimination strategy figured out, as usual!
So, how many times do you think we will have to replay an eliminations match because the score will end tied 0 to 0?
Raul
: Is it OK to modify the robot after the competition has started? ie: having two separate chassis and moving the motors and controls over during lunch. Of course all variations would be within the rules.
: Bill B
#0047 (ChiefDelphi)
No Fair
Posted on 10/25/2000 8:24 AM MST
In Reply to: Re: Modifications posted by Raul on 10/24/2000 11:05 AM MST:
Raul
No fair! You are sealing Car Nacks material. One of the predictions was going to be that there will be more that one match with a score of zero to zero.
Bill B
#0047 (ChiefDelphi)
Re: Tie score?? What will we do????
Posted by Mike Aubry.
Engineer on team #47, Chiefs, from Pontiac Central and Delphi .
Posted on 10/25/2000 6:57 PM MST
: Raul
My bet is that won't happen very often. But in case it does, we'll see what else we can cook up to keep things moving along. I'm sure the crowd doesn't want to see a bunch of 0-0 ties and then a bunch of redos! You force me into considering tie breakers! Yechhhhh
#0047 (ChiefDelphi)
Q&A Dance with the gal who brung ya
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 10/24/2000 2:38 PM MST
Question:
Is it OK to modify the robot after the competition has started? I.e.: having two separate chassis and moving the motors and controls over during lunch. Of course all variations would be within the rules.
Answer:
Our initial inclination was to say yes on this one, but we thought it over and kicked it around a bit and decided against it.
Teams may make design changes during the competition. They are also allowed to make their robot re-configurable. But to have wholesale mechanism and/or chassis changes midstream makes us nervous.
Basically, saying 'Yes' to this proposal would allow teams to have 2 entirely different robots and to pick and choose what robot to run based on the situation. Rather than face this situation, we are implementing the 'Dance with the gal that brung ya' rule.
So...
1)
Modifications of things like gear ratios between matches (e.g. by changing pulley diameters, sprockets, etc.) are allowed.
2)
Teams are allowed to have mechanisms that they leave off or move to another position or orientation, BUT they must be able to weigh in with all intended mechanisms included on the scale. Also they must pass inspection in every intended configuration.
3)
This rule is not intended to prevent a team from improving their robot during the competition. BUT it is not in the spirit of the competition to have these improvement be a work around of item 2 above ('Oh, we just decided that Arm#1 wasn't working as well as we intended, perhaps this here Arm#2 we happen to have brought with us from California'). Similarly, teams that tend to 'improve' their robot when playing against teams of type A only to decide to 'un-improve' their robots whenever playing teams of type B will get a lot of scrutiny, as they may be looking to avoid having to weigh in with all the various modules they want use.
Major re-designs will, of course, require re-inspection. We don't expect these rules to stop determined cheaters, but we will at least make such folks go through the discomfort of looking us in the eye and lying to us.
Again, a little Gracious Professionalism here goes a long way.
Joe J.
[IMG] code is Off
modifications for easily traversing the ramp Solace General Forum 2 22-01-2003 20:50
odification allowed gail OCCRA 6 10-10-2002 04:27
Wheel Modifications? archiver 2000 1 24-06-2002 00:13
Segway Modifications...... Clark Gilbert Dean Kamen's Inventions 11 06-12-2001 21:59
Drill Modifications Mike McIntyre OCCRA 0 16-10-2001 06:09
