Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 11-04-2008, 18:07
3DWolf's Avatar
3DWolf 3DWolf is offline
Boots - Head Programmer / 3D
AKA: Jake
FRC #1502 (Technical Difficulties)
3DWolf is on a distinguished road
Send a message via AIM to 3DWolf Send a message via MSN to 3DWolf
COM Port data reading without dashboard
I'm currently at home and can't get to my demo board so I can use dashboard to read data from a serial port for testing some things, is there any program or anything that will give me similar outputs as dashboard straight through the serial port? I have a flight throttle that I want to toy with and see what kind of data I can get off of it.
You can call it the programming teams fault, but we'll just force your arguments nil.
There are 10 kinds of people in the world -> Those who understand binary and those who don't.
WYSIWYG - In FIRST: Greatness
Unread 11-04-2008, 21:54
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: COM Port data reading without dashboard
What part of the control system do you have?
Unread 11-04-2008, 21:56
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
When we were testing, we just messed around with the controls while logging the data into a CSV file. Then we played back the CSV file like serial output.
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
Unread 11-04-2008, 22:02
3DWolf's Avatar
AKA: Jake
It's an older device, I think it's supposed to connect through the joystick which I can't find or another cable, because it has a round connector on it as well as the the direct serial connection. I know it's getting power at least because when I plug it in there are 2 buttons that toggle lights on, and a 3 position switch that does the same.
On the device itself it says the following (brackets are just placeholders)
Weapons Control System Mark II
FSN AR/C NAV023-12
MEETS MIL. E-5400
REV. CODE C-17.031
Thrustmaster
Made in the USA
Then it has a list of approved planes on it.
I'm not really sure where I got this thing from, I've had it for ages, never used it.
Unread 11-04-2008, 22:12
This guy?
Unread 11-04-2008, 22:16
3DWolf's Avatar
AKA: Jake
Exactly that. It's left handed, however that shouldn't matter
Unread 11-04-2008, 22:37
This is some wierd joystick... I'm not sure if it works standalone.
Your best guess is this document, I hope it helps:
http://www.flyfoxy.com/ThrustmasterFAQ.html#Topic1.1
Unread 11-04-2008, 22:40
3DWolf's Avatar
AKA: Jake
I don't really need the documentation on the device itself, I just want a way to display what it's giving me, like dashboard. I would just use dashboard but I'm at home and don't personally have an IFI controller =P
Unread 11-04-2008, 22:45
You said there is a serial connector on there? Try hooking it up to a serial port on your computer, and see if the software on this website is of any use:
http://www.flyfoxy.com/FoxTwo.html
Unread 11-04-2008, 23:05
3DWolf's Avatar
AKA: Jake
The programs on there are configures, and I can't seem to get the data I'm lookin for off of there. I guess I'll just have to wait until Monday and throw it up on the dashboard at school.
I just want to see what I'm getting like px_sw_top, aux1, aux2, etc out of it.
Unread 12-04-2008, 12:26
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
The gameport connection is not serial. You can read the values at the connector with an test meter by measuring the resistance.
Unread 12-04-2008, 13:35
3DWolf's Avatar
AKA: Jake
I don't quite think you guys understand what I'm trying to do. I basically want a Dashboard, but without the IFI Robot Controller and OI board in front of me.
Unread 12-04-2008, 13:48
Vikesrock's Avatar
Happy Birthday! Vikesrock Vikesrock is offline
Team 2175 Founder
AKA: Kevin O'Connor
Right and what Dad1279 is saying is that the Gameport interface is not serial. A serial port sends digital data bits one at a time. The gameport uses analog signals for the joystick values.
The IFI Dashboard interprets the streams of bits sent by the OI into the values you see. The OI gets these values from the gameport by interpreting the analog signals on the gameport pins for the joystick and mapping the variables for the buttons to digital signals on other pins.
If the joystick you're holding has a serial port connector on it, then it will not connect directly to the OI, so it is difficult to answer your question. If it has a gameport it can be connected to the OI easily, but I don't know of any program that will allow you to read gameport values in the manner that you want (doesn't mean it doesn't exist).
Unread 12-04-2008, 15:49
3DWolf's Avatar
AKA: Jake
The device actually has switches on it for analog and digital, could this aid in any way?
Unread 14-04-2008, 00:17
Jared Russell's Avatar
Taking a year (mostly) off
If you hook it up to a Windows PC, you can view all of its outputs in Control Panel->Game Devices.
I think this is what you are asking for.
Does reading from the serial port work? Alan Anderson Programming 16 29-01-2008 07:15
Reading Servo Data? Gary Dillard Control System 4 07-02-2006 16:50
Getting Dashboard data in OS X 10.4.4? Billfred LabView and Data Acquisition 3 28-01-2006 15:02
Reading binary data from a file and writing it in VB complete Programming 1 02-01-2006 21:21
dashboard data stream archiver 2000 10 23-06-2002 22:56
