Go to Post Are we really at the point where the only useful thing we can discuss is Dean's choice in timekeeping apparel? The man has a watch. He uses it to tell time. Do we really care how much it is worth, or who made it? I would be much more interested in what he does, not what he wears. - dlavery [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:15
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Q&A: Are these mat'ls legal?
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 10/29/2000 7:16 AM MST
In Reply to: Are these mat'ls legal? posted by Jason Rukes on 10/26/2000 6:53 AM MST:
Question:
PVC endcap used to close the end of a PVC tube. Legal or Not Legal?
Answer:
Yes
Question:
Screws or other fasteners used to gain traction on the field. Just like the set screws on CD5's wheels. Assuming no damage will be caused to the field of course. Legal or Not Legal?
Answer:
The edges cannot sharp. AND we cannot even THINK about hurting the gym floor below the carpet. We will have to make the call on a case by case basis. We will error on the side of protecting our right to have another CDI next year (which means we can not risk having the carpet ruined).
Question:
Spacers (nylon, aluminum, etc.), used like a washer, to fill the gap between two materials clamped by a fastener. Legal or Not Legal?
Answer:
Washers are legal, if used within reason (e.g. a 0.5 inch stack may be reasonable while a 2.5 inch stack of washers may not be).
Question:
Regarding above, could an aluminum spacer be considered aluminum tubing, making it a legal additional material?
Answer:
I will allow it.
Question:
PVC cement used to fasten PVC tubing to PVC fittings. Legal or Not Legal?
Answer:
I believe that this is specifically allowed by the rules. But to repeat, Yes this is legal.
[IMG] code is Off
gas shocks legal? ajlapp Rules/Strategy 3 01-02-2003 22:42
is this legal? archiver 2001 2 24-06-2002 00:58
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
Ya'll think this would be legal? archiver 2001 3 23-06-2002 23:58
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
