Go to Post if you do make a marshmallow robot, that would be pretty sweet. - smurfgirl [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 17-01-2008, 13:49
RyanCesiel's Avatar
RyanCesiel RyanCesiel is offline
Project Manager / Web Designer
FRC #0245 (AdamBots)
RyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud ofRyanCesiel has much to be proud of
Send a message via AIM to RyanCesiel Send a message via Yahoo to RyanCesiel
phpBB3 Forum Icon Set (Tango Icons)
On Team 245's forum we're currently using a combination of the Tango Icon Library and the Silk Icon set for our forum icons (the stuff that shows if there's a new post or not and the other stuff). I'd thought I'd share them because several people contacted me about them.
Here's a few, if you're wondering what they look like:
Download!
Feedback?
AdamBots.com - Winner of 10 Best Website Awards!
Unread 18-01-2008, 13:02
RyanCesiel's Avatar
Re: phpBB3 Forum Icon Set (Tango Icons)
Digg it if you like it!
Unread 21-01-2008, 00:39
RyanCesiel's Avatar
If anyone uses these, I'd be curious to see them on another forum. Let me know if you do!
Unread 12-04-2008, 08:22
Faceleg Faceleg is offline
Faceleg is an unknown quantity at this point
Thanks! I've used them here, minus their colour.
http://waikato-golden-key.org/forum
They're a bit warped in places, I'll fix it if I'm explicitly told to, otherwise... I'm sick of working on that forum.
Unread 12-04-2008, 13:05
RyanCesiel's Avatar
Cool, I really don't care if they're warped like that, but they would definitely look a lot better if they weren't. Make sure your not telling your SMF forum to set a standard size for the icons.
Unread 12-04-2008, 22:10
Is there an easy way to check/change this?
Unread 13-04-2008, 12:19
RyanCesiel's Avatar
I'm a little busy this weekend, but I'll check into it on Monday.
Unread 14-04-2008, 21:29
RyanCesiel's Avatar
I've been having a little trouble with the SMF install. However, if I remember correctly, I think you have to edit the size of the image in the theme file. If you not sure where that is, look for a folder called theme/skin/style or something like that and find the default. Hopefully, I'll get a SMF forum installed so I can test some things.
Unread 25-04-2008, 23:14
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I don't know if you're still on it, Ryan, but I'm almost done installing SMF now, so I can check it soon...
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 26-04-2008, 10:06
RyanCesiel's Avatar
Go ahead and do that.
Thanks for the help.
Unread 29-04-2008, 17:53
synth3tk's Avatar
AKA: David Thomas
Ok, you have a different skin, but I found:
{FORUM_ROOT}/Themes/{SKIN_FOLDER}/BoardIndex.template.php
Unfortunately, I'm not certain because: A) you're using another/custom skin, and B) I don't see any image size attributes. I'll look into it more later tonight. Not too much different from phpBB's folder hierarchy, though.
phpBB3 Released synth3tk Website Design/Showcase 12 14-01-2008 17:16
Pictures, icons! Arefin Bari CD Forum Support 15 27-05-2004 21:56
Icons MikeFromTeam71 Chit-Chat 1 02-03-2003 15:02
Icons RJS Chit-Chat 4 08-06-2001 19:07
mystery icons Joe Johnson CD Forum Support 2 07-06-2001 22:09
