Go to Post I would rather KEEP the structural integrity of my skull, thank you. - carpedav000 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:15
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Wheel Attachment to sprocket/shaft?
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 10/26/2000 4:33 PM MST
In the pictures section, there is a set of pictures showing how to attach a sprocket and wheel to a shaft. However, it is somewhat unclear as to what is actually being done in some of the pictures. Is is possible to get a short written set of instructions, describing what is being done in the pictures? Thanks...
Nate
#0047 (ChiefDelphi)
Re: Wheel Attachment to sprocket/shaft?
Posted by Matt Berube.
Engineer on team #49, Delphi Knights, from Buena Vist High School and Delphi Automotive Systems.
Posted on 10/26/2000 7:10 PM MST
In Reply to: Wheel Attachment to sprocket/shaft? posted by Nate Smith on 10/26/2000 4:33 PM MST:
: In the pictures section, there is a set of pictures showing how to attach a sprocket and wheel to a shaft. However, it is somewhat unclear as to what is actually being done in some of the pictures. Is is possible to get a short written set of instructions, describing what is being done in the pictures? Thanks...
: Nate
The most easiest solution, and the one that the most teams will likely use, is to put the alluminum spacers that were provided into the wheel hubs and bolt one of the two sizes of big sprockets to the wheels. The trantorque can then be used to fasten the sprocket to a 1/4' shaft that goes through the sprocket and the wheel and is supported with the brass bushings on both ends. I hope that this is helpful.
Matt B.
Team 49
[IMG] code is Off
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
3D Model of skyway 20" wheelchair wheel?? Elgin Clock 3D Animation and Competition 2 14-09-2002 16:41
wheelchair wheel + F.P. motor ?? archiver 2000 2 23-06-2002 22:44
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
