Go to Post Saying that something cannot be done, is always good inspiration for someone to find a way to do it. - Josh Hambright [more]
Go Back   Chief Delphi > Competition > Championship Event
  #181   Spotlight this post!
Unread 12-04-2008, 20:57
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Archi-medes!
Originally Posted by thefro526 View Post
Our elevator only goes up to knock the ball down if the robocoach gives it the go up signal, if there is no signal then no ball knock off. The only times we missed in Philly were when the signal didn't get to the 'bot in time which is because there's about a .25 second window of error because in the time it takes the robot to move the 27 feet to the overpass ~2 seconds or so is the same time it takes to process the signal from the robocoach and move the elevator up
thefro526: I have an idea for you. If you're arm is servoed, why don't you tell it to go up a little even before it's told to go up?
If you're arm is not servoed, why don't you have your arm go up for 1 second, so it won't be high enough to mess anything up if you don't want it to knock off, and then if you do want it to knock off, have it continue going up. It should get rid of the problem you're experiencing with getting a signal to the robot right away... we had the same problem.
So who's got the best hybrid in Archimedes? We can knock down one ball and get 3-4 lines. Our ball knock off works if the ball is in front of us at the beginning about 90% of the time and we get 3 lines if we are not impeded but usually we're impeded at the turn for the 4th line.
For your consideration: http://www.chiefdelphi.com/forums/sh...520#post735520
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
  #182   Spotlight this post!
Unread 12-04-2008, 21:13
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Archi-medes!
-q
Q, We don't use an arm we use an elevator (not really a big difference) but it's not servoed.(Our teams feedback is the drivers) So what happens is, at the beginning of the match the elevator is held about 5 feet off the ground so that it has to travel about 14" or so to get to knock off height. it takes it about a second to get to that height. Our main problem is the aim into the robot while its against the wall. we shoot at almost at a 90degree angle to our IR sensor. We may add some pool noodles to gain a larger height margin of error so that if we are late with the signal the noodles will hit the ball anyways. Check us out in Archimedes if you get the chance and I'll give you the breakdown.
-Dustin
-Dustin Benedict
  #183   Spotlight this post!
ttldomination's Avatar
Sunny
Re: Archi-medes!
Where do we get the archimedes division badges????
1648: 2013-2014
5283: 2015
  #184   Spotlight this post!
Unread 12-04-2008, 21:21
thefro526's Avatar
Mentor for Hire.
Re: Archi-medes!
I forget the thread I got it from, It's not mine but here's the code. Just paste it into your sig. [*IMG]http://img.photobucket.com/albums/v437/daunte2moss07/FIRST/archimedesuserbar.jpg[/IMG]
Take out the star from the first [IMG] and it'll work
-Dustin Benedict
  #185   Spotlight this post!
Unread 12-04-2008, 21:25
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Re: Archi-medes!
>In competition: one, two, and three.
round.
AR-CHE-ME-DES!
-q
So thats what happen to 2683 (vid two) I'd miss that match.
IMHO 1024 is one of the most robust and reliable robots there are... even when running like sh... umm a Ford it stll holds it own and wins.
The drive team works together like a QB & Center that been playing for years.
There program team is top notch and their can do spirit is unstoppable.
I know there are a lot of folks that love 1114 as if it was Obama...
They good... I'll give them that... but 1024 has a better overall package!
See you in the winners circle Q
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
  #186   Spotlight this post!
Unread 12-04-2008, 21:55
Sunny
Re: Archi-medes!
Thankx for the banner.
1648: 2013-2014
5283: 2015
  #187   Spotlight this post!
Unread 12-04-2008, 21:59
jess523s's Avatar
jess523s jess523s is offline
Righto
AKA: Jessica
FRC #2550 (OCPro)
Team Role: Webmaster
jess523s is an unknown quantity at this point
Send a message via AIM to jess523s
Re: Archi-medes!
Greetings from team 2550.
We're rookie all-stars from Oregon and in the Archimedes division. I'm excited : )
This is our first year at the world championship, obviously, and looking at this forum, I think we're pretty lucky to be put in this division.
Now hopefully the airline problem doesn't force us to go on a 38-hour road trip and won't strand our team captain and our team manager in Pittsburgh and San Jose : \ </pessimism>
Looking forward to seeing you all in Atlanta!
  #188   Spotlight this post!
Unread 12-04-2008, 22:08
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: Archi-medes!
team 2604 reporting for duty
we won greatlakes due to great alliance partners and got rookie all-star their, also we got 10 hours and a good design to make a shooting end affector (how hard can that be) hope fully we will come out with a shooter that can match rush's railgun like power.
Is now an engineer thanks to FIRST.
  #189   Spotlight this post!
Unread 12-04-2008, 22:17
Sunny
Re: Archi-medes!
well...now we're calling in...well...
Team 1261 on board. We have a good design but didn't win any regionals. We're hoping to have a strong showing in divisions and hopefully make it to Einstiens...lady luck hasn't been with us, but lately things have turned around.... Who's next?
1648: 2013-2014
5283: 2015
  #190   Spotlight this post!
Unread 12-04-2008, 22:21
Re: Archi-medes!
I see we're doing a formal role call eh? haha
Team 11 MORT is ready for Atlanta.
Chesapeake regional champs with 1418 and 2016
New Jersey regional finalists with 2590 and 1980
We're excited to be with an awesome group of teams and can't wait to play with you all.
-Akash
  #191   Spotlight this post!
Unread 12-04-2008, 22:22
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
Re: Archi-medes!
Driving to Atlanta is actually pretty fun but than again I stop for the night and only drive like four hours the second day. Well we will see you guys in Atlanta and best of luck with your airline and travels. Remember we are going to make Archimedes the most spirited division.
  #192   Spotlight this post!
Unread 12-04-2008, 22:39
XXShadowXX's Avatar
They call me Cody.
Re: Archi-medes!
driving heck yeah!
taking a bus W00t! (naturally going with another on the bus)
  #193   Spotlight this post!
Unread 12-04-2008, 22:40
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Archi-medes!
definitely wont be a problem with all of the oinking (=
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
  #194   Spotlight this post!
Unread 12-04-2008, 22:42
Danny McC's Avatar
AKA: Danny McCanney
Re: Archi-medes!
That and I hear that Warrior Pride is pretty spirited. I am going to try and get everyone on my team to be spirited and pumped the whole weekend, but sometimes they dont like to be. So if you see 816 slacking off in the spirt department let me know.
  #195   Spotlight this post!
Unread 12-04-2008, 22:47
Re: Archi-medes!
Speaking of spirit, anyone know where to get those thunder clapper things? Or if anyone is bringing some down if you could drop some by MORT please
preferably black or yellow
