Go to Post 50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary. - Joe Ross [more]
Unread 12-04-2008, 22:38
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: 3-3
Originally Posted by XXShadowXX View Post
computer can not generate random, computer have not or will never understand random, random is something that can only be generated by a intelliegnce and then it can still be predicted to a degree.
Random in a computer is a complex algorithm faking random, its really really really really complex so the answers seem random but the more data you have the closer you can build a similar algorithm, see a math genius its possible.
Not really scouting skills just having Internet and sitting on TBA for the next four days straight
Agreed on the fact that computer cannot generate random, but the fact is that it has human input.
the computer can read the time that the operator tells to start the randomizers animation and use that random variable to generate where the balls will end up. This method would be truly random.
plus, if you get on TBA for the next 4 days,(which some of our people will actully do ) they will have quiete the best scouting DB.
-Borna Emami
Team 0x27
Unread 12-04-2008, 22:40
BornaE's Avatar
Re: 3-3
Originally Posted by Vikesrock View Post
If the pseudo-random algorithm uses the system clock as a seed it would be extremely difficult if not impossible to discern any type of pattern from watching matches as the exact time that the ball randomizer was run is not known. This is an easy and common way to get a good seed for a pseudo-random algorithm.
EDIT: The method mentioned by Uberbots above is also used and would also render any amount of match watching useless.
photofinish
nice
-Borna Emami
Team 0x27
Unread 12-04-2008, 22:44
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: 3-3
all dynamic systems are predictable see chaos theory...
If you can apply chaos theory to the FIRST scoring computers while watching a match, worrying about your team, and cheering your brains out (oink oink boom), then ill eat my hat.
and how is using the clock more complex to resolve? combining all registers in the processor is millions of unknowns (depending on the proc), including the clock..
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 12-04-2008, 22:56
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: 3-3
all dynamic systems are predicatable see choas theory...
more complex but it can be found, everything has answer and math hasn't falled us yet (or me)
I would contend that with the given information about the initial conditions (very little) and the size of the data set, that no actual pattern could be discerned. My guess is that any pattern that comes out of observing TBA matches would be coincidence and not actually related to the algorithm used in the randomization process.
Unread 12-04-2008, 23:01
BornaE's Avatar
Re: 3-3
You can figure out where the balls will be if you know the time, but you will not know the time.
-Borna Emami
Team 0x27
Unread 13-04-2008, 07:33
GaryVoshol's Avatar
Cogito ergo arbitro
Re: 3-3
I agree that the algorithm won't be completely random. But you will likely have to go to several million regionals before you can detect the pattern.
(since 2004)
Unread 13-04-2008, 12:39
BornaE's Avatar
Re: 3-3
Nice!!!!!!!!
one at the corner of every street every day
-Borna Emami
Team 0x27
Unread 13-04-2008, 17:03
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: 3-3
curses, you have point...
Is now an engineer thanks to FIRST.
