Go to Post Don't bash FIRST for what you do not know. - David Kelly [more]
Unread 12-04-2008, 13:42
zivo123 zivo123 is offline
FRC #1690 (The Asnswer)
zivo123 is on a distinguished road
Gyro problem..HELP!
Hi everyone,
we have entered the last day of training for us (we are flying to america on monday!) and our Gyro suddenly became odd- when we turn it somewhere, it begins to count and gets to 15000~..
has anyone expirienced something like this before?
is it a problem with the sensor, the wiring, or the program?
Any comment or advice would be extremely helpful!
Thanks, Ziv
Ziv Oriol
Email - ziv_o123@walla.co.il
Our first game in the Israel regional:
http://www.youtube.com/watch?v=a_92wGPhWig
Unread 12-04-2008, 14:30
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Re: Gyro problem..HELP!
Which direction are you turning and at what speed?
Is it any different than what you were doing before?
Are you using Kevin's or your own code, EasyC, or RobotC?
Unread 12-04-2008, 14:36
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
i know they are using Kevin's code.
i think the direction doesn't meeter, happens in both, and they did not have a gyro before.
don't count on the i think thing though =]
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 12-04-2008, 14:53
Almost correct Liron
We've had a gyro and it is acting the same way as the new one..
if you have any more questions we would love to help you help us.
Ziv Oriol
Unread 12-04-2008, 16:04
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Originally Posted by zivo123 View Post
Hi everyone,
Thanks, Ziv
Are you using any interrupts?
-Borna Emami
Team 0x27
Unread 12-04-2008, 16:06
yes, we are using Kevin's original code..
Ziv Oriol
Unread 12-04-2008, 16:13
BornaE's Avatar
Interrupts can corrupt the gyro variable.
To solve this problem, you need to make a secondary variable that holds the gyro value from the last cycle, and if your actual value changes drastically, then you will replace it with the old value and continue.
We had the same exact problem and now it is fixed.
Hope that this helped,
have a safe trip,
see you in Atlanta
-Borna Emami
Team 0x27
Unread 13-04-2008, 12:09
11Mort11's Avatar
11Mort11 11Mort11 is offline
AKA: Alex Joss
FRC #0011 (MORT)
11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold
Send a message via AIM to 11Mort11
are you letting it calculate the bias?
Unread 13-04-2008, 14:09
yes.. we are letting it calculate as in Kevin's original code - j < 300
Ziv Oriol
Unread 13-04-2008, 14:22
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Is it increasing even when you stand still?
Also, look at the ADC input - is that fairly static or is it rapidly changing when the robot stands still?
Unread 13-04-2008, 19:21
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Check your wiring to your analog input.
An unconnected analog input will "count" up like you describe. I suspect you may have a broken wire, or a disconnected wire.
Unread 14-04-2008, 00:15
Jared Russell's Avatar
Taking a year (mostly) off
I second that. The pullup resistor and low pass capacitor in the analog input circuitry will combine to pull the voltage up to VCC slowly in the absence of an input.
Unread 14-04-2008, 03:44
Could you possibly tell us hoe to wire it? and if you have ready we also need the wiring of the GTS and the IR..
Ziv Oriol
Unread 14-04-2008, 12:06
Tom Line's Avatar
The usfirst.org website has a sensor guide that will describe the different pins and what they are for. Likewise, the email they sent out in December has a link that has a .pdf file that describes how to wire the IR board.
gyro problem Guarana Programming 9 03-03-2008 15:48
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Gyro not accurate - Problem naor52 Programming 15 27-01-2006 16:50
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
