Go to Post ... six weeks, it's too long, but not long enough. - Stillen [more]
Unread 13-04-2008, 19:47
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Delay code isn't delaying.
I'm working with Kevin Watson's 3.0 compatible FRC framework. I have code in the begining of my Autonomous() function that should cause the robot to wait, based on a few constants defined in Autonomous.h. It doesn't seem to work, and just takes off immediately. Could it have something to do with the fact that the field control system spends a moment in teleop before jumping to autonomous in the begining?
I attached a .zip archive with my entire workspace.
Thank you for helping.
-Guy Davidson
Unread 13-04-2008, 20:13
Re: Delay code isn't delaying.
Might it have something to do with this line in autonomous.h?
#define WAITING_TIME 0
Unread 13-04-2008, 20:29
That line is commented out as part of this block:
#define LOOPS_IN_A_SECOND 38
#define TICKS_IN_A_FOOT 156 //163 * 23 / 24
#define DRIVE_FORWARD_1 10 //45 //in ft
#define DRIVE_FORWARD_2 10 //in ft
#define DRIVE_FORWARD_3 40 //in ft
#define DRIVE_FORWARD_4 10 //in ft
#define TURN_LEFT_1 65 // in diffs
#define TURN_LEFT_2 57 // in diffs
#define ANGULAR_INCREMENT 5 //in diffs
#define LINEAR_INCREMENT 156 //163 * 23 / 24
#define POSITION_INPUT_1 rc_dig_in17 //0 && 0 = LEFT, 1 && 0 or 0 && 1 = CENTER, 1 && 1 = RIGHT
#define POSITION_INPUT_2 rc_dig_in18 //0 && 0 = LEFT, 1 && 0 or 0 && 1 = CENTER, 1 && 1 = RIGHT
The copy I hope it's using is defined a few lines later:
#define WAITING_TIME 8
Is there any way that's causing issues?
Unread 13-04-2008, 20:37
I didn't think the preprocessor cared about comment lines. Are you getting any compiler errors or warnings about trying to redefine a symbol?
Unread 13-04-2008, 20:38
Nope. No errors or warnings what-so-ever, as far as I can see.
Unread 13-04-2008, 20:47
iTHOS=awesome iTHOS=awesome is offline
FRC #1258
iTHOS=awesome is an unknown quantity at this point
Send a message via MSN to iTHOS=awesome
The best thing to do for delays is make a counter that does everything. Here is a few lines that I used for our robot in the Tacoma Regional:
int timer = 0;
if(timer < 72)
/* 72, if I remember right, is about 2 seconds, this number can be adjusted however you need it to be */
timer ++;
else
// This is where the remainder of autonomous functions occured
Unread 13-04-2008, 20:52
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
It cycles 40 times a second right? So you can just make a function that returned i / 40 so you can say if(timer < 2) which would be the actual amount of seconds. I know it's basic math to just multiply by 40, but it makes the code a little more readable for someone that doesn't know that.
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
That's pretty much what I have there.
Unread 13-04-2008, 20:56
FRC #1258
if that is what you are doing, I don't know what the issue would be. Can you copy and paste your delay code here so I (or anyone else) can help you?
Unread 13-04-2008, 20:59
It's in autonomous.c in the attached archive. Since it's also based on stuff in autonomous.h, I left it in an archive. Would it help if I copy both .c and .h here?
Unread 13-04-2008, 21:03
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
The only thing I can think of now is changing this:
if(auton_counter < WAITING_TIME * LOOPS_IN_A_SECOND)
to this:
if(auton_counter < (WAITING_TIME * LOOPS_IN_A_SECOND))
Maybe try printing out WAITING_TIME and LOOPS_IN_A_SECOND and see what it's outputting.
Unread 13-04-2008, 21:12
What does your debug statement say for the value of counter?
Unread 13-04-2008, 21:16
FRC #1258
The code is fairly confusing for me as to what you are trying to do. The way I learned programming makes this very hard to read, no offense. I just can't figure out what is wrong with it.
Unread 13-04-2008, 21:29
I too find the highly compact style a hindrance to readability. I actually reformatted the relevant lines in order to make it easier for me to see what the code was trying to do.
I don't remember who said it, but I agree with the philosophy that says a programmer's job is to write documentation that compiles into a working program.
Unread 13-04-2008, 21:44
That's the next thing I was going to check. I put it in there during our last competition in hopes of getting around to test it there, and I haven't been able to yet. I'm hoping to do that early Thursday morning in Atlanta.
Kevin Watson's gyro code isn't compling Griffin Programming 3 15-02-2008 20:34
Delay jasonpeinko Programming 8 18-01-2008 15:56
Delay Help! waiakea2024 Programming 7 21-02-2007 12:41
Delay Gal Longin Programming 1 09-12-2004 10:37
Delaying/Dampening motor response cadets Control System 4 05-02-2004 18:27
