Go to Post A better way would be better..... - WizardOfAz [more]
Unread 14-04-2008, 12:38
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
pic: Built For Clearance
Unread 14-04-2008, 12:40
zachjo's Avatar
zachjo zachjo is offline
Shake 'N' Bake
FRC #0171 (Cheese Curd Herd formerly Extreme Engineering)
zachjo is a jewel in the roughzachjo is a jewel in the roughzachjo is a jewel in the rough
Re: pic: Built For Clearance
do you have any close up pictures of your system to lower/elevate the elevator? Are you using box tubing that telescopes out? Do you have good luck with not tipping?
unicycling----It's like doing a wheelie forever!
Shake 'N' Bake
Unread 14-04-2008, 18:19
Karthik1's Avatar
830 Alumni
We use box tubing with our own linear bearings. Each stage slides along the side of the previous stage. Every instance where two faces of metal rub against each other there is Teflon tape (not the stuff used in pneumatics), this is what allows the elevator to slide very smoothly. The elevator is also powered in both directions, so that we don't have to wait for gravity to pull it down. So far we have not tipped while our elevator has been extended, but it is always a concern for an arm design. We try to concentrate our weight in the back and drive carefully when the elevator is extended. The elevators best features are its speed (less than 3 seconds to fully extend), and the fact that it is self leveling as it extends, to prevent binding. Here are a few more pictures:
"freedom is voluntary self control” Mahatma Gandhi
Unread 15-04-2008, 15:49
Hairygutball's Avatar
Hairygutball Hairygutball is offline
AKA: Slopsema
Team Role: Driver
Hairygutball has a spectacular aura aboutHairygutball has a spectacular aura about
too bad you cant see the "xx" now because of the gripper
Our Safety Captian lit his cat on fire
Unread 15-04-2008, 16:38
Nice lift, it reminded me of this from 2005
pic: Virginia's rear ground clearance falconmaster Extra Discussion 7 25-01-2008 23:31
Source Code for Built-in Modules weissert Programming 1 24-10-2007 15:41
pic: 100% Student Built CD47-Bot Extra Discussion 30 14-04-2005 07:43
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 15-02-2005 17:02
pic: Custom Built Stopwatch Kyle Fenton Extra Discussion 18 18-12-2004 20:57
