Go to Post Nonetheless, I would welcome it, as long as [The President] didn't restrict the number of discs that a Robot could hold. Oops, wait, too late, the GDC already did that. :-) - MooreteP [more]
Unread 14-04-2008, 03:40
zivo123 zivo123 is offline
FRC #1690 (The Asnswer)
zivo123 is on a distinguished road
Sprocket Wheels!
Hi everyone!
We have a couple of ideas how to make our robot faster and all of them are involving sprocket wheels:
we need a sprocket wheel for a motor (the thick one) with more than 15 teeth good for #35 chain, or a thin sprocket wheel with less than 22 teeth (also #35)
Is there anywhere other than AndyMark and IFI to buy sprocket wheels? what we need can't be baught on both of them.
Will there be an AndyMark/IFI/other store in the Dome?
also, if anyone has anything that he thinks might help us we would love to hear about it.
Thanks, Ziv.
Ziv Oriol
Email - ziv_o123@walla.co.il
Our first game in the Israel regional:
http://www.youtube.com/watch?v=a_92wGPhWig
Unread 14-04-2008, 03:55
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Sprocket Wheels!
You can try McMaster-Carr:
www.mcmaster.com
search on "sprockets" and look for ANSI 35 Roller Chain sprockets.
I'm not sure how you would place the order from Israel, but if you can place the order, they will ship to your hotel in Atlanta.
Good luck.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 14-04-2008, 04:46
Thanks A Lot!!!!!!!!!!!
Ziv Oriol
Unread 14-04-2008, 08:13
Billfred's Avatar
Billfred Billfred is online now
Actually, as I recall, the 1/2" bore sprockets McMaster-Carr sells don't have keyways broached in them. If you have means of getting that done, then it's a non-issue, but if you don't have the means (and don't want to try your machine shop luck), you may want to try Grainger instead.
Unread 14-04-2008, 08:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
That is correct. Mcmaster has have two types - one with a set screw, and one without. The set screw is not to be trusted - you will need to broach for a keyway.
You are also correct - grainger sells them WITH keyways. Make sure you get the right sized keyway!
http://www.grainger.com/Grainger/items/6L776
Also, from the quick glance I just took, the smallest shaft size with keyway that Grainger has is 1/2 inch.
Unread 14-04-2008, 09:26
Billfred's Avatar
Good point--I was making the (perhaps-flawed) assumption that they were using the AM Toughbox. Your mileage, of course, may vary.
Unread 14-04-2008, 10:27
i'm not sure we have the "means" because im not sure what we need in order to do it.. anyway why not trust the machine shop? if the have the means we have the skills..(we have a proffessional in these things)
EDIT: BTW we are using the AM toughbox
Ziv Oriol
Unread 14-04-2008, 12:30
Billfred's Avatar
You'd need a broach and an arbor press in order to make the keyway. It's an easy task if you have them, a challenging task if you don't. My only leeriness with depending on any event machine shop is that you're risking a wait considering the number of teams present. I tend to prefer approaches that involve fewer resources beyond my control, but your tolerance for such risk (which, having never been to Atlanta with a team, I could be tremendously misjudging) will vary.
Unread 14-04-2008, 12:55
Aren_Hill's Avatar
Build Nifty Things
We've got both! Just stop on by 1625 Winnovation in Newton and we'll get a keyway broached for ya.
A guy who likes robots.
Unread 14-04-2008, 13:18
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
i am now officialy inlove with you guys. In the name of all Israeli teams - thank you!
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 14-04-2008, 14:17
AcesPease AcesPease is offline
Teacher Mentor
AKA: Bill Pease
FRC #2836 (Team Beta)
AcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud of
Stock Drive Products also markets a range of hubbed and hubless sprockets. Good luck with your new drive
Bill Pease FIRST Team 2836 Team Beta
Formerly FIRST Team 176 Aces High
WFF 2010
Unread 14-04-2008, 14:42
Aren_Hill's Avatar
Build Nifty Things
we also have a bandsaw, drill press, belt sander, moto tool, full tool chest, Air compressor, and much more, so feel free to stop by for anything ya need
Unread 14-04-2008, 16:04
Tottanka's Avatar
AKA: Liron Gurvitz
well i personally am not going to make it to the Championships, but still good to know that =]
Unread 14-04-2008, 17:04
Thanks a lot!!
we are now in the boarding area going to owr flight.. that is really great news for us! thanks!
Ziv Oriol
6 wheels with only 2 powered wheels bhsrobotics1671 General Forum 15 14-01-2008 17:28
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
TO much traction??? (ifi wheels or AM wheels) Heretic121 Technical Discussion 9 04-02-2006 12:09
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
