Go to Post So, the game hint is there is no game hint. - tindleroot [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:19
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Modification?
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 11/2/2000 10:05 AM MST
In Reply to: speed controllers posted by Pat Casey on 11/2/2000 9:58 AM MST:
I might be able to help if you clarify what you mean by 'modification'...also, keep in mind that the contents of the control box are on the NoMod list, which means that other than plugging wires into the terminals, everything inside has to stay pretty much the way it came to you. As for other minor 'modifications', such as the braking jumpers, I can't say what the official call on that would be...Joe?
[IMG] code is Off
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
last years speed controllers..... archiver 2001 9 23-06-2002 23:44
Capacitors on speed controllers archiver 1999 7 23-06-2002 22:09
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
