Go to Post Besides, if you look back on anything you've already made and can't find any flaws that can be improved, you're doing it wrong. - artdutra04 [more]
Unread 14-04-2008, 15:22
RoarRoar RoarRoar is offline
RoarRoar is an unknown quantity at this point
help with Operator Interface and FRC robot Controller
Hello
I have make a submarine and I will use Operator Interface and FRC robot Controller to control my 4 motors (thrusters) on submarine.
Sow I need some help with my Operator Interface and FRC robot Controller.
The Operator Interface and FRC robot Controller is new,sow i dont no what I shall do.however
I have connect all cables,2 Analog joystick and the 4 Motor Controls to FRC robot Controller and the Operator Interface,I use two RS232 converter to RS485 instead of Radio Modem, because the Radio Modem don`t work under the water, sow I have a long cabel.
When I power up Operator Interface and the FRC robot Controller with RS232 converter to RS485, the LEDs indicator on Operator Interface and FRC robot Controller indicate this:
Battery Power : GREEN Blink
Program State : GREEN Blink
Radio Modem : RED Solid
RC Hardware : GREEN blink
RC Mode : OFF/ no LED
Operator Interface
Operator Interface
POWER ON : GREED Solid
DATA TX : GREED Solid
VALID RX : GREED Solid
NO DATA/Radio : NO LED
MAIN Fault : NO LED
AUX Fault : NO LED
RADIO Fault : NO LED
INTERNAL Fault : NO LED
Robot controller
VALID RX : GREEN Blink
NO MAIN BATT : RED Solid
LOW MAIN BATT : Orange Solid
CODE ERROR : RED Solid
BACKUP BATT : NO LED
I will take a photo off Operator Interface and the FRC robot Controller to morrow.
Unread 14-04-2008, 15:26
BHOP BHOP is offline
FRC #0399 (Eagle Robotics)
BHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud of
Re: help with Operator Interface and FRC robot Controller
read the manual, at innovation first...
you have no radio connection, use a red "teather"(a serial cable with 2 male ends), then/or plug in the radios...
BHOP
ME CoE University of Michigan
503 Frog Force 830 Rat Pack
399 Eagle Robotics
Unread 14-04-2008, 15:30
matt91 matt91 is offline
FRC #1779 (G-F.O.R.C.E.)
matt91 is an unknown quantity at this point
Send a message via AIM to matt91
I think u got 3 problems. 1 its not reconizing a main battery, or its seeing it as very low. 2 it doesent like your code. 3 it doesent like what your doing with the radios. That's all I got.
Unread 14-04-2008, 16:24
EricH EricH is online now
If the tether isn't plugged into the "Tether" port on either the Robot Controller or the Operator Interface, it won't work. You'll need a red tether as noted (or an equivalent M-M or F-F (I forget just which)) due to the fact that the ports are the same on both the Operator Interface and the Robot Controller.
Unread 14-04-2008, 23:07
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
F-F
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 14-04-2008, 23:11
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Originally Posted by RoarRoar View Post
Hello
Operator Interface
Operator Interface
MAIN Fault : NO LED
AUX Fault : NO LED
Robot controller
You need RS-422 not 458, but you can use the tether cable.
Also if you modify the Antenna on the radios, they will work under water.
-Borna Emami
Team 0x27
Unread 14-04-2008, 23:46
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
Use the tether ports. But you want a longer cable. We cut the tether cable in two and inserted used some old multi line phone cord. We used some of the extra wires for camera and other sensors. More info at:
http://www.phxhs.k12.az.us/education...detailid=44216
Watch the waterproofing. The water pressure will force water through the tiniest opening, even a nick in a cable.
Unread 15-04-2008, 11:21
ok, I have remove the RS485 converters from Tether,and hook up a Female-Female cable, all LEDs on Operator Interface and Robot controller is GREEN.
You can see this on image.
Sow I can not use a RS485 converters into the Tether port.
I need a longer cable about 100 Meter,how can I do that.
I have talk to http://www.ifirobotics.com they say I can use a RS485 converters, with RS 485 can you use 1000Meter cabel with only 2 Wire TX- TX+
What shall I do no,to run the 4 speed controllers and the 4 motor, forward,reverse?
you can see on the image I have hook up 2 Analog joystick to control the 4 motor.
I have never do this before.
Unread 15-04-2008, 11:27
With the setup you have, the default code should work. (I'm not sure exactly how to set it up, but I think you've got it set right.) Try moving one stick forwards and backwards or side-to-side. Make sure that the robot won't move first! Hopefully, one of the motors will turn on. If nothing happens, the programmers should be able to help.
But, make sure the "Disable" light on the Operator Interface is off first. (I can't tell from the picture--the light reflects at the wrong color. It looks like it's off.)
Unread 15-04-2008, 13:25
Racer26 Racer26 is offline
You will also need to connect your motors to Victor 884 Speed Controllers (or similar) which are connected by PWM cable (3 wire, 0.100" spaced pins) to the RC. I forget the outputs to which the default code outputs, I'm sure someone else here will chime in.
Unread 15-04-2008, 13:29
BornaE's Avatar
Well then if you want to use the RS485 Convertors, you have to connec them to the RADIO porst instead of tether. the tether port is not a standard serial cable, it provides power to the OI as well as the data.
-Borna Emami
Team 0x27
Unread 15-04-2008, 14:14
ok.
I have moving one stick forwards and backwards,but nothing happens.
I have connect they 4 Speed Controllers to PWM1 PWM2 PWM3 PWM4
I have not use Victor,I have use Speed Controllers from parallax.com
I will try to connect the RS485 Convertors to the RADIO porst,and se whats happen.
What do you mean about that
Unread 15-04-2008, 14:31
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
You should download the RC and OI manuals from IFI. Based on where you have the joysticks plugged into, your speed controllers should be plugged into pwm1, pwm2, pwm5, pwm6. It looks like you have them in pwm13, pwm14, pwm15, pwm16.
Your joysticks should be wired per the analog inputs in the OI manual. For each axis - one side of 100k linear pot to an analog input pin , center to +5vdc aux pin, other side not connected.
It looks like your joysticks are not centered. The OI LEDs for pwm1 and pwm2 should be on green and red to indicate neutral.
Last, check the compatibility of the paralax speed controllers to the output from the RC pwm signals.
Good luck,
p
Andy Brockway
Team 716, The Who'sCTEKS
Unread 15-04-2008, 14:37
On the Operator Interface, there is a small section in the middle column of LEDs at the bottom. It is labeled "Competition Control" and has one light: "Disabled". If that light is orange, your controller is disabled and will not respond to anything until you take it out of disabled mode. If it is off, you're good to go.
If it is on, I'm not sure how to take it out of disabled mode without a dongle (fancy switch). The schematic for one is available on IFI's site. It might be a good idea to make one anyway, just to help the robot run only when you want it to.
Unread 15-04-2008, 16:25
now I have try to connect the RS485 converters to the RADIO porst,but dont work, after I have remove RS485 converters from RADIO porst,and hook up the Female-Female cable into the Tether port again,come only 1 GREEN LED and 1 Yellow LED on FRC robot Controller.same on the Operator Interface ,but is have 2 Green Led and 1 Red Led
Program State : YELLOW
Radio Modem : no LED
RC Hardware : no LED
Operator Interface
POWER ON : GREED
DATA TX : GREED
NO DATA/Radio : RED LED
sow what happen?
Is the FRC robot Controller or Operator Interface broken
operator interface help sonicx059 Technical Discussion 1 21-01-2008 15:43
BASIC operator interface and robot controller John Gutmann Electrical 2 26-04-2005 21:45
Operator Interface is crazee !!! HELP punarhero Programming 30 17-07-2002 14:23
Operator Interface, Need help. Jordan A. Technical Discussion 13 22-01-2002 16:57
Robot Controller & Operator Interface troubles patrickrd Technical Discussion 10 25-10-2001 07:36
