Go to Post CAD or it didn't happen - R3P0 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:20
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: control box
Posted by Michael Martus.   [PICTURE: SAME | NEW | HELP]
Coach on team #47, Chief Delphi, from Pontiac Central H.S. and Delphi Automotives Systems.
Posted on 11/4/2000 4:05 PM MST
In Reply to: control box posted by Pat Casey on 11/3/2000 6:06 AM MST:
Are you sure you need to re-calibrate the speed controllers. I will ask joe if this is ok.
Have you checked the trim on the Joy stick? It must be in full up direction on one of the controls to work at all ( I think if memory serves me right it was the outside joy stick that controls the victor). I will check with Joe regarding this issue.
I have built several robots with these controls and have had no problems at all and so have many others?
I will have an answer soon.
[IMG] code is Off
Box Control Tton General Forum 2 12-02-2003 23:38
control box size gail OCCRA 2 24-09-2002 05:30
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
Gray box limitations Tim Skloss Technical Discussion 1 23-01-2002 07:38
Modular Control box assembly Andrew Wyatt Technical Discussion 4 29-11-2001 15:44
