Go to Post Read the manual. Know the manual. Love the manual. - Koko Ed [more]
Unread 15-04-2008, 11:27
Re: help with Operator Interface and FRC robot Controller
With the setup you have, the default code should work. (I'm not sure exactly how to set it up, but I think you've got it set right.) Try moving one stick forwards and backwards or side-to-side. Make sure that the robot won't move first! Hopefully, one of the motors will turn on. If nothing happens, the programmers should be able to help.
But, make sure the "Disable" light on the Operator Interface is off first. (I can't tell from the picture--the light reflects at the wrong color. It looks like it's off.)
operator interface help sonicx059 Technical Discussion 1 21-01-2008 15:43
BASIC operator interface and robot controller John Gutmann Electrical 2 26-04-2005 21:45
Operator Interface is crazee !!! HELP punarhero Programming 30 17-07-2002 14:23
Operator Interface, Need help. Jordan A. Technical Discussion 13 22-01-2002 16:57
Robot Controller & Operator Interface troubles patrickrd Technical Discussion 10 25-10-2001 07:36
