Go to Post One of those things I learned in kindergarten - never introduce myself to an “enraged” woman wielding a clipboard. - Mark McLeod [more]
Unread 15-04-2008, 14:19
Back after 4 years off
FRC #5279
Re: C Programming Homework Help Needed
An easy way to go from decimal to binary.
Psuedo Code
While number>0
push a bit equal to (number mod 2) onto the end of the binary number
divide (number-(number mod 2)) by 2
end while
that should get you started, as a couple of hints, if all you are doing is printing out the number you may not need the array, also c truncates numbers when you do integer math, this simplifies the loop slightly.
See what you can figure out and feel free to ask for help
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
C Programming Homework Help Needed Pat McCarthy Programming 53 27-09-2008 22:15
programming help needed krunal Programming 3 29-01-2007 00:18
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
URgent Programming Help needed rcubes85 Programming 4 15-02-2005 23:21
