Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Go Back   Chief Delphi > Technical > CAD
Unread 15-04-2008, 13:55
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
computer build for CAD use (and games)
Hi cd
not entirely sure if this is the right forum, but it's probably good enough
I'm going to college next year and I have 1.5k to make me a computer that will handle some autocad work, and do ok on whatever games my floor decides to LAN.
Here’s what I got:
GIGABYTE GA-MA790X-DS4790X ATX Ultra Durable II AMD Mobo
With a
AMD Athlon 64 X2 5000+ Brisbane 2.6Ghz 65W Dual-Core Black Edition Model ADO5000DSWOF
Cooled by a
ZALMAN 9500A 92mm 2 Ball
And some
CORSAIR Dominator(2 x 1GB)DDR2 1066 Model TWIN2X2048-8500C5D
With a
EVGA 512-P3-N862-AR GeForce 9600GT Superclocked 512MB
And two at raid0
Western Digital Caviar RE WD2500YS 250GB SATAII
Powered by a
ABS Tagan BZ700 700W Modular PSU
All in a
Thermaltake Armor Series VA8003BWS w/ 25CM Fan
Then the essentials like a dvd±rw, a card reader, articsilver & remover, G9 mouse, slim eclipse keyboard, 22” Samsung LCD, some uv cathodes and uv SATA cables…
Any input would be much appreciated, thanks.
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 15-04-2008, 15:51
CraigHickman
Posts: n/a
Re: computer build for CAD use (and games)
If you're doing CAD, I have only one suggestion: More RAM. I've been able to lag out a workstation-level machine with not too much effort, all because Inventor is a RAM pig.
You may want to bump the RAM up to 4GB.
Unread 15-04-2008, 16:07
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Originally Posted by GMKlenklen View Post
And two at raid0
Before you decide on RAID0 you should read Jeff Atwood's post about RAID, and some of the other material he links to.
I agree, more RAM is good.
Eric Haskins KC9JVH
Unread 15-04-2008, 16:15
Happy Birthday! Akash Rastogi Akash Rastogi is offline
Don't you have to go with a 64 bit OS for 4 gigs of RAM to work well? That may be one of the reasons he may not b/c I know some games aren't built for 64x and a lot of other software doesn't run well on 64x either. That's one of the reasons I didn't go for 4 gigs. Or can it be cross compatible and work the software as a 32x install? I don't know much about os's and RAM.
Unread 15-04-2008, 18:10
AKA: Eric Haskins
It's true that to get full use of 4gb of RAM you need a 64 bit machine.
As for campatibility, In December I built a Core2 Quad(Q6600) machine with 4gb of RAM, running Vista Ultimate x64, and I've had no issues running x86 applications. There are some apps which have install issues, but that's due to the mfg, not Vista x64.
EDIT: Just so no one yells, XP x64 had issues early on, but the Vista x64 release has been relitivily stable.
Eric Haskins KC9JVH
Unread 15-04-2008, 19:53
CraigHickman
Posts: n/a
Yes, to have 4 GB you need a 64bit machine. However, 3GB is still more than 4GB, and is much better than 2. If you're going to be doing a lot of CAD, you're going to be wanting a lot of RAM.
Unread 15-04-2008, 19:57
Thanks for clarifying. I haven't dual booted with x64 since it came out so idk how much better it got.
Unread 15-04-2008, 20:44
Team 1708 Dave's Avatar
Team 1708 Dave Team 1708 Dave is offline
Lead Robot Inspector
Team 1708 Dave is on a distinguished road
Funny you should be in the same boat as us. I just bought a new laptop for my son to use with autocad & inventor. We got a HP dv9825nr at Best Buy. This is brand new on the market. Intel Core 2 Duo processor T5550 1.83 Ghz. 17" widescreen HD Brightview. 320 GB (5400 rpm). 4 G of DDR2. GeForce 8600m GS w/ 512MB dedicated graphics memory. And of course Vista. I chose this unit because of the hardware and capatability with cad. Sure I wish it had a 7200 rpm with fall protection. The HP product has gained a better rep. recently and we had no problem with the first HP laptop we got for my oldest son. Which is the same but half the machine. Cost was 1,149.00 I know a Dell has a 20" screen and that would also be helpful with cad. If possible I would stay with a laptop unit instead of a desk model. I had both over the years and I don't think I ever buy another desk model. I hope this helped. Dave
P.S. Cad is not supporting Vista but the next verision is and will be out soon.
Unread 15-04-2008, 22:40
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If you have a x64 system, go for more RAM.
Otherwise, I'd also get another hard drive. 250Gb ain't what it used to be, especially if you want to start loading it up with a ton of games (many take up several Gb of hard drive space each). Right now - just for my laptop - I have a 40Gb internal, a 60Gb portable USB external, a 320Gb USB external, and a 750Gb Firewire 800/eSATA external.
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-04-2008, 23:33
GMKlenklen's Avatar
The "Masonater"
more ram can't be a bad thing. I'll go with it... which probably means i'll grab some G. Skill. or something cheeper.
I've been told that 450W PSU should be more than enough for this system... true? false? might as well have more for when i upgrade?
after looking on autocad's website, they say that basically all workstation graphics cards are tested for use with autocad... so should i run a workstation graphics card, or a desktop gaming card?? I do still want to play games occasionally!
Thank you,
-of the MASMabots-
Unread 16-04-2008, 00:04
I wouldn't risk a 1500 dollar computer on 450w. I personally would go with around 550. I have an Antec NeoPower 550 that's been running my system for a while now and I love it. Check this out for help..
http://www.techspot.com/vb/all/windo...do-I-need.html
Mainly this:http://www.extreme.outervision.com/index.jsp
Unread 16-04-2008, 01:55
AKA: Eric Haskins
I agree 250gb probably isn't enough.
On my desktop I have a 500gb drive, and that's about 75% full. Mostly media from FIRST events, and Virtual Machine images.
For my laptop I've got an 80gb internal(50% full) and two 120 gb USB powered WD externals(each about 75% full)
For my machine, it's vary close to this machine w/ some substitions for price and availiability, I'm running a 550w PSU, and havent' had any issues.
PSUs are cheap, I'd be safe and spend a few extra bucks.
As for graphics cards, it depends on your budget. I wouldn't get less than somthing in the NVIDIA 8600/8800 area, but if you've got the cash go as high as you want. I'm running an 8600gts, and all my games run fine on it. Plus right now it's only $80 from Newegg after a rebate.
Eric Haskins KC9JVH
Unread 16-04-2008, 14:19
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I remember building a computer just to build one. Those were good times. Nowadays I live in practicality, and rarely use more than 200GB for videos. I capture video inputs all the time and save them off to a compressed format that take up 1-2GB each for long HBO movies or TV shows, then eventually put those on DVDs in a notebook.
These days, since the computer is in my room, I want QUIET. A good computer is a computer that I can't tell is there! I remember spending $50 on a heatsink that looks like a butterfly simply because the ratings said it was the quietest thing ever. On top of that, the ATI card I have also has dynamic fan speed control, so I only hear it when I turn up the graphics on a game. Now if I could only figure out how to get rid of the ultra-high frequency from the nearly-silent spin of the hard drive....
I hear solid state drives don't make any noise...
GitHub
Unread 17-04-2008, 23:07
GMKlenklen's Avatar
The "Masonater"
Ok, i have redone my list... although this will probably happen like ten times cuz i'm gonna order parts at the beginning of june when i get paid.
With a
Cooled by a
And two sets of (4 gigs total)
G.SKILL 2GB (2 x 1GB) DDR2 1066 Model F2-8500CL5D-2GBPK
With a
EVGA 512-P3-N801-AR GeForce 8800GT 512MB GDDR3
And two at raid0
Powered by a
OCZ GameXStream OCZ700GXSSLI ATX12V 700W PSU
All in a
so i got some cheeper ram, and more of it
a less controvercial graphics card
a better psu... at least it's cheeper even tho it's an octopuss
i'll probably just add more hdd's as i need them. knowing me, 500gigs is just fine for uh.... a long time. i only have like 55gigs on this laptop, and just got an 80gig external... which i'll probably fill up half-way this summer depending on how many people's iso's i gotta keep incase they crash&burn after my free tech suport XD
thanks guise for all the help!
Thank you,
-of the MASMabots-
Unread 17-04-2008, 23:55
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
CAD + Vista = BAD from what hear
I just bought a new dell with XP just so i could run pro-e and autocad. Good luck with your building
What kind of computer do you use for programming? Rohan_DHS Programming 21 05-01-2006 11:52
Use your computer for good, and join another type of FIRST team. Elgin Clock Chit-Chat 5 17-06-2005 07:42
Bad and Good news for Computer Science AIBob Math and Science 8 31-01-2005 18:59
Bad and Good news for Computer Science AIBob Programming 5 31-01-2005 14:02
What computer games do you love to play? DarkRedDragon Chit-Chat 55 29-01-2003 07:45
