Go to Post (I'm sure that Dave is holding his breath for "welding with Jello".) - jgannon [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 17-04-2008, 20:36
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: NEW 2009 Control System Released
Originally Posted by writchie View Post
There are only 3 NON-OVERLAPPING CHANNELS for b/g because the channels are 5 MHz wide and 802.11b/g occupies a little more than 20mhz. The channel number refers to the center frequency. You can use center frequency on channels 1, 6, 11 without mutual interference. Some 802.11n signals are 40 Mhz wide. The channels for 802.11a are 10 mhz wide and every other channel can be used to provide 8 NON-Overlapping channels.
In 802.11b/g in the U.S. you can use any of 11 channels you like as your center frequency but there will be interference with other stations using channels less than 5 from you channel. That is not to say that running say 6 access points on 1, 3, 5, 7, 9, and 11 won't work - they will work but there will be mutual interference, retransmissions, etc.
They said 11 and 11 usually means 11... They'll release the details with time just wait a little bit.
Also don't just think of the US there are teams in Israel, Puerto Rico, Chile, Brazil, Netherlands, Great Britain, and hopefully more next year.
Buying the 2009 control system BornaE FRC Control System 9 16-10-2008 17:16
2009 Control System Feature Wishlist tdlrali FRC Control System 47 17-06-2008 00:25
pic: 2009 Control System, Mounted Billfred FRC Control System 23 01-05-2008 19:02
2009 Control System Possibility? Racer26 Rumor Mill 121 25-04-2008 09:05
Forum Request: Post-2009 control system? Billfred CD Forum Support 3 22-04-2008 16:22
