Go to Post You can't derail a thread that had no "rails" to begin with. - bkahl [more]
Unread 17-04-2008, 19:31
nickbotix nickbotix is offline
FRC #1168
nickbotix is an unknown quantity at this point
Question Radio Boost/Range Extender?
Hey CD Forum!
I have a question about the FIRST radios supplied in out kit. Our team wants to be able to control our robot [on the off season, not at competitions] from a far greater distance than we currently can with our radio connection.
In this scenario, limitless tether cables won't do the job. So, I was wondering if anyone had found -- or could find -- a rather simple modification of the the FIRST supplied radios to extend its range.
We want to be able to control the robot on a playing field from the top of the bleachers.
Our team also has some of the older radios to work with, so the answer doesn't need to specifically deal with the revised radios.
Thanks for all of you help and comments!
Unread 17-04-2008, 19:47
Re: Radio Boost/Range Extender?
Originally Posted by nickbotix View Post
Hey CD Forum!
How far of a range do you want? The FRC radios have a pretty decent range for normal use. What kind of application are you thinking of?
I'm not trying to discourage you, but I can't think of anything offhand. I'm also curious as to why the extension is needed.
Unread 17-04-2008, 19:50
FRC #1168
Unread 17-04-2008, 21:49
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Last fall my dad and I built a bot for Holloween and had it driving down my sidewalk a good 200-300 FT. I believe that is way more than bleachers to field.
-Mike AA
Unread 17-04-2008, 21:51
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Have you tried this range. Not knowing how large your gym is, but if it's a typical gym, you shouldn't have a range problem at that distance.
Now, if you're talking a stadium.....
If you don't have any kind of tether running from where you are to field-side (i.e. to allow the regular radios to be closer together), then you need to create some kind of wireless relay system.
I think we'd like to hear back as to weather you simply tried it first. Then we can work from there.
Jacob
Unread 17-04-2008, 22:42
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
On a similar note, our team 2158 has experienced a drastic reduction in radio range recently for one of the new radios. We were doing a demo in a parking lot and we only had about 30-40 feet of effective distance. That's bad, seeing as we have a 13-foot forklift. We can't really have our signal cut out at full speed.
On our OI board, we have the radio box screwed down underneath the OI controller (on standoffs), and the antenna sticks out from the side. Any problem there?
Unread 18-04-2008, 02:24
dgitz dgitz is offline
FRC #2219
dgitz is an unknown quantity at this point
XBee Radios have an effective range of about 300 feet outdoor, and about 150 feet indoor, its just a RS232 connection so you could probably just hook them up and you'd be running, just like the FRC radio's. You'd have to set up the network but its not too hard.
Unread 18-04-2008, 07:57
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Yes, there is a problem.
These radios have two antennaes. The external one, and the internal one. In addition, these are standard dipole antennaes. That means that the shape of their "field" is like a donut, with the antennae sticking through the hole of the donut.
Putting the radio on it's side means that at times, one or both of the antennaes will be pointing AT the operator interface antennae. Contrary to what may be intuitive, this is the absolute worst orientation to have the antennae. Both the antennaes and the robot antennae "box" should be vertical for best reception.
Unread 18-04-2008, 08:55
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
You might be able to build a directional Yagi type antenna to use on your controller. Boosting the signal (adding watts) could be a violation of FCC laws and you would need to add filters to reduce harmonics also. The contollers should work fine for line of sight over a distance of 300". Look up some of the ham sights on how to add a "director" and "reflector" elements too the controller antenna. If done right you should be able to more than double your range.
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
Unread 18-04-2008, 10:14
Gdeaver Gdeaver is offline
FRC #1640
The kit radios are FCC certified as a radio and antena modual. It's against FCC regs to modify the antena, But who is going to catch you.
Unread 18-04-2008, 12:02
It has been spotlighted that someone (I forget who) said "Stop it with the "Break the rules, just don't let anyone know" already!" (approximate quote)
Don't modify the antenna if it's against the regulations. I don't care if you will/won't get caught. Professionalism forbids it (let alone Gracious Professionalism).
Unread 18-04-2008, 13:51
Engineer's Avatar
KØBR
AKA: Rick - KØBR
I can not condone this action as the FCC can impose a $10,000 fine and confiscate any and all radio transmitters in your possession/home if you are caught. They can also make it illegal for you own any radio transmitters in the future. That includes your garage door opener, cell phone and cordless phone etc. It's not worth the risk. As for modifying the antenna, I'm not sure if it is illegal to add a reflector and director elements to the antenna but warrants investigation. Reflectors and Directors are just elements of a certain length in front and behind the active antenna with no DC electrical connection the active antenna. The simply direct and collect the RF energy in designate direction. FIRST states that is not legal to modify the controllers for competition.
Hello, from KØBR.
Unread 19-04-2008, 11:37
Clifford Clifford is offline
AKA: Clifford Harrison
FRC #2658
Clifford is an unknown quantity at this point
You could always do a range test. From what I've read in this thread, people are getting very different max ranges. I know we tested ours at school at got a little over 500 feet, and that was with a 20 ft dirt hill between the operator and the robot.
Clifford Harrison, Alumni & Mentor
FRC Teams 2658 & 3749
FTC Team 5135
Unread 19-04-2008, 12:45
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
For starters you may want to look into changing the wireless link into a 802.11x based system. That way you can legally use YAGIs or omnis and and higher power units.
I'm not clear if you are allowed to modify the antenna or not. From my understanding FCC regulates the power emissions of wireless devices. E.g. 200mW for user 802.11 devices. What antenna, using RX amps, or how many of such devices within an area shouldn't be a problem.
| jamesyong.net |
FVC2007, FTC2008
Unread 21-04-2008, 09:45
Nick,
In addition to some of the good info here, the best reception using the antennas supplied is to have them parallel. The minimum coupling between antennas takes place when they are at right angles to each other. The radios do in fact, have two antennas, one external and one internal. At the RC modem, the external antenna is receiving data from the OI, and the internal antenna is sending data back to the OI. Although the dashboard data is affected by this antenna, the software will allow communications with errors on this return link. (according to IFI reps)
As always, mounting any antenna near metal, causes it to detune. This effect is at it's worst when the end of the antenna is near or touching other metal parts. By their nature, antennas of this type, mounted on robots that travel near the ground, would have the best coupling when in a vertical orientation. That is why the IFI supplied antenna farm at competitions is in the vertical orientation.
To use another type of antenna would require retuning the output coupling of the radio, something most teams are not equiped to handle. The band that our radios use have specific limits set by the FCC that allow unlicensed operation in that band. One of those limits is Effective Radiated Power, ERP, which is affected by antenna gain and output power. The majority of teams would not be able to measure ERP so it is ill advised to try to increase that specification.
You can however, move the radio closer to the field and feed it with a longer serial cable. Be careful that the cable you use has low loss as the power for the radio also runs in that cable.
Voltage Boost AndyB Electrical 5 26-01-2007 08:56
CIM motor shaft extender (adapter) Arkorobotics Motors 9 08-02-2006 06:53
Ford Probe + Boost = KABOOM Mini-D67 Chit-Chat 8 06-12-2005 07:53
Every kick is a boost Mr. A General Forum 2 26-03-2005 15:22
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
