Go to Post Unconventional isn't necessarily innovation. - AdamHeard [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #121   Spotlight this post!
Unread 18-04-2008, 01:31
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: NEW 2009 Control System Released
Without having read the entire thread, here's some thoughts:
  • No more MCC18! GCC does PowerPC, so any platform should be able to work
  • How is WindRiver IDE different from Eclipse? What fancy additions from them do teams need?
  • Are things like the downloader going to be open sourced (like the libraries)?
  • How much control over the LCD does software have?
  • How are modes implemented? How is the software (at the equivelent of the IFIlib level) structured?
  • Does the PowerPC bit imply things like multitasking? Could we write some fanciful background thing to do some cool stuff?
  • I like their solution for the OI. Still hackable, but no longer needing the chicklet hacks (what kind of restrictions does the USB have?)
  • 8 40-amp breakers? 8???
  • The Digital Side Car appears to be IFI's toy. I suspect a number of teams will like the addition of SPI
  • I guess I'll have to make time to actually mentor a team this year, just to keep current
  • If something segfaults, what happens to it?
Addendum:
  • C++??? For real? No, NO! Word for the wise: Avoid pointers.
  #122   Spotlight this post!
Unread 18-04-2008, 01:40
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If they want security, then why not just use WPA2 encryption [with certificates]?
For example, for general use at driver training, demonstrations, and possibly off-season events, either a public certificate can be used or they can just operate the robots over an unencrypted network. But at every event, a unique and time-sensitive certificate is loaded onto the controllers for WPA2 authentication.
After the competition, the time-sensitive certificate deactivates, and the team can return to using the robot on unencrypted networks.
Art Dutra IV
世上无难事,只怕有心人.
  #123   Spotlight this post!
Unread 18-04-2008, 02:27
AKA: Dr. Brooks
no team (WRRF)
Authentication of each and every packet on the wireless network is far more important in this environment than the conventional notion of wireless network security.
Lets assume that the field control system, the robots, and the operator stations are all connected to each other by one ethernet cable and no outside influence is possible. This is the goal of conventional wireless network security.
You still want every packet from the field control system to be authenticated, so that the other nodes on the net can't spoof it. You also want every packet back and forth between your robot and your operator station to be authenticated so that another node on the net can't spoof this communication.
Going further, if robots on your alliance are going to communicate with each other, you what these packets to be authenticated so that spoofing can't happen, and every robot would have to use public key methods to do this so that it can publish the data required to authenticate packets coming from it.
If you are going to spend any effort on network security for the communication on the competition field, the best thing to do is assume that one of the nodes that you have allowed on the net will attempt a spoof. If you prevent that, you don't have to worry so much about what nodes get on the net.
Eugene
  #124   Spotlight this post!
Unread 18-04-2008, 02:42
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
um how about you set MAC authentication on the AP, simple and fairly effective, going to take people a little while to figure out your MAC.
All of those other ones take little time to crack. And people have enough trouble with getting radios to work at home and that is straight forward. Adding certs, now you are asking for it.
Remember this is not a NSA secret project... Or is it, what have you all gotten me into.
A2D Solving the Imaginary Error Function...
  #125   Spotlight this post!
Unread 18-04-2008, 07:20
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Originally Posted by Astronouth7303 View Post
Addendum:
Why is that such a strange thing? Microchip was the odd man out when it came to implementing a C++ implementation on their microcontrollers.
  #126   Spotlight this post!
Unread 18-04-2008, 07:29
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Originally Posted by M. Krass View Post
If we're not getting a new control system each season, I hope that we can expect lower registration fees in 2010 and beyond. I don't know how it's possible to justify charging teams the same fees while giving them fewer resources.
They may be amortizing the expense across several years, then using the remaining revenue as a license fee to support operations and maintenance.
  #127   Spotlight this post!
Unread 18-04-2008, 07:35
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by Andy L View Post
They said 11 and 11 usually means 11... They'll release the details with time just wait a little bit.
Also don't just think of the US there are teams in Israel, Puerto Rico, Chile, Brazil, Netherlands, Great Britain, and hopefully more next year.
Guys - reread the documentation before you get too excited. This system will be able to handle multiple robots per channel. That means packetized data identified much like nat packets are identified to be sent to each computer by the router.
Also, I'm feeling slightly better about the possibilities of C - because of this statement:
-Parity between C/C++ and NI LabVIEW libraries
If NI truly sticks to that and releases a C/C++ library when they review a labview one with the same basic functionality, it will all be good.
  #128   Spotlight this post!
Unread 18-04-2008, 07:58
Gdeaver Gdeaver is offline
FRC #1640
It looks like the power distribution pannel produces 24 volts for the compact rio. So what happens under heavy load and the 12 volt battery is pulled very low? I don't see any back up battery. I didn't see any specs on power consumption for the rio and the moduals and the access point. Did some one forget how first teams love to abuse thier motors and Batteries? Seams to me there needs to be a battery back up.
  #129   Spotlight this post!
Unread 18-04-2008, 07:59
FRC #1640
  #130   Spotlight this post!
Unread 18-04-2008, 09:11
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Originally Posted by Pat McCarthy View Post
The youtube video on this page reminds me of the "Powerthirst" video.
At 1:08 in that movie, they say 'Underwater exploration'
Water Game
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
  #131   Spotlight this post!
Unread 18-04-2008, 09:12
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Originally Posted by chuckstudios View Post
Something that upset me a bit was that they said we wouldn't be able to modify the VHDL for the FPGAs inside the new controller. That means we have no real idea of what's going on inside it, and can't unload any "special" tasks to it. Then in the same breath, they say the libraries will be hosted on a Sourceforge-alike site. That's not hypocracy, I swear >_>!
I've been using cRio's this semester. Compiling FPGA code takes from 5 minutes for a simple (simple!) program, to around 15 for a still-not-that-complex-but-does-more program. It finally made this xkcd comic make sense.
  #132   Spotlight this post!
Unread 18-04-2008, 09:27
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
First off, this is still early in it's stage so a lot of that is being worked out. And just like the sidecar isn't covered, maybe they did it just for show. Patience, people. Patience.
Secondly, dude, double post. Plz baleet won, kthnxbai.
Did they say anything about speeding it up a bit, because I know our programmer will go nuts trying to compile last-minute code. Especially if we're working with complex robot code, I don't want to wait an hour to see if it works.
Also, I love xkcd. That one didn't make sense to me either.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
  #133   Spotlight this post!
Unread 18-04-2008, 09:31
Adam Y.'s Avatar
Adam Y.
no team (?????)
Just like all platforms. What you wrote isn't a strike against National Instruments more than a perfect example as to why HDLs are different from conventional computer languages. I was doing research on FPGAs and found that other people were amazed at the length of time for a simple VHDL example to compile. It makes sense because the compiling process isn't the same for a HDL as opposed to a language like C++.
  #134   Spotlight this post!
Unread 18-04-2008, 09:37
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Originally Posted by JesseK View Post
Essentially, if they gave out how they were deciding to ensure security, someone somewhere would be that much closer to hacking into it.
Security through obscurity is an awful, awful way to approach security. Once someone figures out your algorithm (and someone will), then it is game over. If we assume that the attackers are going to figure out how you're securing it anyway, why not let people with good intentions know the algorithm as well so they can point out potential flaws?
The strength of a security system should lie in the attacker not knowing an easily-changed key, not in them not knowing the algorithm.
  #135   Spotlight this post!
Unread 18-04-2008, 09:54
mgreenley
Posts: n/a
For reasons that eugenebrooks has covered (post #120), (post #123), namely being able to identify each node and prevent spoofing, simply filtering MAC addresses may not be enough. Both nodes that are supposed to be connected and/or a rouge node (say a malicious fan), could spoof a MAC address.
I agree that MAC filtering would probably suffice for differentiating between each robots traffic. However, I feel that wireless security is an important aspect to consider since, in the eventuality that there was a cracking attempt on the network, nobody would want to have their team and robot suffer. Network security at a FIRST event is once instance where I feel the Regan saying of "Trust but verify" is quite pertinent.
Also, a second on Bongle's post as well; security through obscurity is one of those funny things that I've read about working out poorly more than a few times.
Buying the 2009 control system BornaE FRC Control System 9 16-10-2008 17:16
2009 Control System Feature Wishlist tdlrali FRC Control System 47 17-06-2008 00:25
pic: 2009 Control System, Mounted Billfred FRC Control System 23 01-05-2008 19:02
2009 Control System Possibility? Racer26 Rumor Mill 121 25-04-2008 09:05
Forum Request: Post-2009 control system? Billfred CD Forum Support 3 22-04-2008 16:22
