Go to Post Generally, when you do something stupid and unsafe, it isn't the best idea to go and tell thousands of people on CD about it. :rolleyes: - Cory [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:26
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Q&A: Sprockets and Crimp connectors
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 11/15/2000 2:48 PM MST
In Reply to: Sprockets and Crimp connectors posted by Jason Rukes on 11/15/2000 1:21 PM MST:
Question:
In the App Notes section about Wheels, Wheels, Wheels, you state: Use a sprocket for a wheel (but remember that uncovered sprockets are not legal so you will have to cover the teeth with something – perhaps plain old chain. Is it legal to use an uncovered sprocket as a roller to collect a ball, as long as the roller will never touch the carpet? I'm assuming the reason that uncovered sprockets are illegal is to prevent damage to the floor.
Answer:
This is fine, assuming that you don't damage the balls or rack either. We only have a limited number of spare balls. If you start hurting them, you will be forced to change your machine design.
Question:
Can we use the supplied crimp connectors as mechanical stops by crimping them on the end of a cable?
Answer:
Perfectly legal.
[IMG] code is Off
