Re: learning LabVIEW
Your comment about FLL and Robolab reminds me--the NXTs are programmed using some relative of LabVIEW. Those might help. |
Teams were given LabView in the past two years KoP so every should have a copy to start teaching themselves with.
It says that the LabVIEW disk and related documents was in a clear bag in the grey tote. I need to find my team's copy too. . .
You can find anything in the KoP by looking at the KoP Checklist, and searching for an item. |
I would suggest doing a couple of things:
1.) Get a copy of Robolab, it is very closely based on labview, this is cover the basic data flow of controlling a robot 2.) Start developing flow chats of signals and their related processes. Understanding what signals you are working with and how to process them makes your life a lot easier! One of the big benefits of labview is that it is really easy to go from (detailed) flowchart to code. |
There is an opportunity to test-drive LabVIEW. You can download a trial copy that will run for 30 days. In addition to this, you can download exercises that will allow you to work within the LabVIEW environment. There are 11 different exercises each one is designed to expand your understanding and comfort level within LabVIEW.
From personal experience with this test-drive, I believe it is a good idea to also have "LabVIEW Measurement and Automation" from the KOP installed on the same machine. At least one of the exercises uses it to create a software input module, but it is not necessary to have that version of LabVIEW installed. |
#7
I highly suggest your team obtains a copy of LabVIEW for Everyone (htp://www.labviewforeveryone.com).
I am an avid LabVIEW programmer, and when I was starting it was worth it's weight in gold! |
#8
The copy of LabVIEW that ALL FRC teams got in their KOP has LabVIEW training materials in it. Look for "LabVIEW Basics" CDs. In regard to the new control system, realize that you need to learn the basics of LabVIEW before learning how to program the new controller - the same way you learned how to program C before/while programming the current control system.
-Danny |
#9
If you have an NXT or are willing to buy one, NI's web site provides free addons to LabVIEW (PC and Mac versions only, sadly) that allow it to be used directly to program the NXT. So grab the copy of LabVIEW out of this year's KOP, download the addon, and get practicing. |
#10
Oh right, I completely forgot NXT's thing was based off labVIEW. That'd really help you understand logic flow. Yes.
| Learning C | idogis1 | Programming | 2 | 07-01-2008 19:56 |
| learning programing | Dakota Snow | Programming | 9 | 27-11-2006 20:28 |
| Learning robots | John Gutmann | Robotics Education and Curriculum | 18 | 25-08-2005 14:13 |
| Learning Photoshop | Jeffel | Computer Graphics | 4 | 13-01-2005 23:08 |
| learning | Tyler Olds | 3D Animation and Competition | 3 | 07-05-2002 22:55 |
