Go to Post The goal isn't to keep the "bad" kids out. The goal is to take the "bad" out of kids, thereby transforming OUR culture. - Michael Corsetto [more]
Unread 19-04-2008, 04:20
beefy23 beefy23 is offline
beefy23 is an unknown quantity at this point
Question Problem with Eclipse and WPILib
I have a problem trying to compile a project in Eclipse, when I try to compile the code, nothing happens, and if there are some errors in the code nothing happens aswell, and it says no error.
when I`ve created the project I have selected “Microchip Embedded Systems” as the type of the project, and selected “FRC 18f8722 WPILib Robot toolchain” on the listbox.
how can I normally build the project?
by the way, is there a way to pass the code to the chip using Eclipse like ifi loader does?
Thank you in advance.
Unread 19-04-2008, 11:20
rogerlsmith's Avatar
rogerlsmith rogerlsmith is offline
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
rogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to behold
Re: Problem with Eclipse and WPILab
We used Eclipse and WPILib this year. It sounds like you have things set up properly, make sure you save your source code. Eclipse will not compile changes that have not been saved.
One thing to try might be to right click on the project and clean it. This will remove object files and cause the entire project to be re-built next time.
There isn't a way, to my knowledge, to have Eclipse load the hex file to the controller. We used IFI loader.
Roger
Roger Smith
Mentor - FRC Team 3357
COMETS - Creating Outstanding Minds, Embracing Technology & Science
Share FIRST videos, photos and experiences at FIRSTObjective.org
Unread 19-04-2008, 17:29
I built the project, but i haven`t found any .hex file in the project directory
Unread 19-04-2008, 23:37
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
The .hex file should be in a folder within your project folder. For example, if you were compiling using WPILib for an FRC controller, the .hex file would be in a folder called "FRC 18f8722 WPILib Robot". This would be a little different for a VEX controller.
Roger
Roger Smith
Unread 20-04-2008, 04:30
No, I haven`t found that .hex in the mentioned directory, but what I can tell you is that im not using Vex.
WPILib and Eclipse Guy Davidson Programming 31 02-04-2008 16:59
Problem with p18cxxx.h and stdio.h sonnguyen Programming 1 12-02-2008 10:42
Problem with easy c pro and mechanum wheels pbrules15 Programming 9 03-02-2007 20:38
Eclipse with CDT Nis Programming 2 15-06-2005 09:31
Problem with reading and writing EEPROM DKolberg Programming 4 16-03-2004 19:29
