Go to Post I don't think finding a way to defend the center goals is un-Gracious Professionalismistic (wow). - Sachiel7 [more]
Unread 20-04-2008, 13:19
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Re: 3 speed transmissions
Originally Posted by neoshaakti View Post
Im pretty new to the concept of two or three speed transmissions (our team just stuck to the KOP toughboxes)
What exact do those pneumatic pistons do?
The pneumatic piston is used to shift the dog between gear sets. The gears that the dog engages are on bearings so they can spin independent of the driven shaft. The pneumatic pushes the dog against the gears locking them against the gear to power it. The dog is basically a rotating disc that engages into the gear via pins or other couplers. In the pictures posted above there is an internal shaft that the pneumatic pushes that is pinned to the dog.
Also if you are looking to make your own three speed transmission I would suggest looking up team 222 Tigertrons. They have a really sweet three speed transmission that they've used in the past (I haven't seen them this year so I'm not sure if they used it again or not).
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Dewalt 3 speed transmissions for sale Happyman Motors 45 19-02-2009 17:24
2 Speed Transmissions in the Future Jherbie53 General Forum 29 09-05-2007 18:18
Are two speed transmissions worth it? thefro526 Technical Discussion 43 19-04-2007 21:16
AndyMark 2-speed transmissions gabrielse Kit & Additional Hardware 3 08-01-2007 11:32
New Ryobi 3-speed drill transmissions! artdutra04 Technical Discussion 5 23-04-2006 19:48
