Go to Post The purpose of the game rules is not to imagine and categorically list everything you should not do, but to give you guidelines of FIRST's intent and leave it to your developing good judgment to know what's acceptable and what is simply skirting the rules. - Mark McLeod [more]
Unread 20-04-2008, 19:56
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Odd Electrical Problems at The Championship
We had similar problems as well... When we would drive from forward to reverse real quickly, it would reset the controller, even though the backup battery was charged and present. I checked all electrical connections, and everything seemed good, but it kept on doing it. We never did solve that problem, we just avoided the problem.
Another issue we had was in our last match, our right drive was not running at full performance, and we found that one of the motor leads going to the victor was lose.
Our IR board never did work in Atlanta. We couldn't get it to work very well even with our remote only an inch or so from the sensor, however it would sometime work, but never in a match...
Oh well... Thanks for a good year FIRST.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 23-04-2008, 14:49
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Our "electrical" problem turned out to be a mechanical problem as well. We had replaced the AM SuperShifter shroud with nylon spacers and lexan. We also attached our chain tensioners to the bolts that bolt together the top of the supershifter. As we tightened the bolts for the tensioners, the top of the transmission would decrease its gap between the plates. It turns out the gap at the top of the transmission was a whole 1/32" too small, causing the main gear the CIMs turn to bind up. We loosened the tensioner bolts on either side and immediately noticed a 3-4fps increase and much longer battery life. We did all of this right before our 2nd match of the day on Friday and nearly gave 1114 a heart attack by almost missing our match
Lessons learned: when trimming off weight from your drive train, some things just simply cannot be replaced.
Surprisingly enough, the AM hubs and flat AM aluminum sprockets that served as our main drive sprockets off the transmissions came away from 3 competitions completely unharmed!
GitHub
Gyro problems, crossposted from Electrical EFastring Programming 4 05-02-2008 10:16
56mm Banebot problems @ Championship Jacob Plicque Technical Discussion 15 19-04-2007 14:11
A Real Transformer? (the robots, not the electrical component) Nick Seidl Chit-Chat 2 02-04-2004 12:23
Odd counter problems Catastrophy Programming 30 16-02-2004 23:41
When the even and odd year/team rule will stop. LizJJury Rumor Mill 19 17-04-2003 19:11
