Go to Post I'm missing JVN's build log this year ! - lynca [more]
Unread 20-04-2008, 20:10
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
pic: vex coaxial swerve
Unread 20-04-2008, 20:12
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: vex coaxial swerve
links aren't working (the ... in the middle makes them impossible to copy/paste too)
Interesting design. How do the swerve modules rotate without driving the wheels and vice versa? It appears to be all through the same axle, and unless you have plans on drilling through the vex gears (which you might) in order to make them rotate about the shaft (dead axle), I don't see how it works.
Unread 20-04-2008, 20:24
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
My guess is that the large gears on each assembly are not attached to the axle and just bolted into the U shape to turn, and the axles of each are driven.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 20-04-2008, 20:51
Alumni
that was my goal. i think i have enough of those gears to sacrifice 4. although it was suggested on the vexforum that i stabilize the driven shaft more.
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
Unread 20-04-2008, 21:23
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Nice, did you consider using the actual swerve drive modules? I think you could.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 20-04-2008, 22:36
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
plt - Here are links to some pics of swerve modules I built. They have the robot chassis supported by 1/4" standoffs that rest on 60-tooth gears that for the tops of the swerve modules. The method might be useful for you.
Pic #0
Pic #1
Pic #2
Pic #3
Pic #4
I want to figure out how to create an even stronger connection between the chassis and swerve modules. I figure that if we were to try to use our designs in a competition, during the pushing and shoving that occurs in them, the axles in our designs (that allow the modules to swerve) will be the point where they bend and break.
I have toyed with the idea of sandwiching an 84-tooth gear between some plates and standoffs. 12-tooth gears around the edges of the 84 could brace it against pure lateral loads and the plates (probably augmented with stand-offs) would prevent twisting about the point where the module's axle enters the chassis frame.
The problem with what I outline above is that if the plates aren't cut to create a circular hole (an annoying expense) that exposes the 84-tooth's mounting holes and allows them to stay exposed as the 84-tooth turns; the connections between the 84-tooth and the rest of the module collide with the framing that holds the 84-tooth (in my imagination ). Maybe you can come up with a rugged way to bring the idea to fruition without ruining too much metal for other purposes.
Blake
Unread 20-04-2008, 23:34
AKA: Bates
FRC #0125 (NUTRONS)
Something I saw in Atlanta which sounds similar to what you might be trying. A team built a turntable using an 84tooth gear. They had it set right on a large flat plate which gave it stability. From talking to them it sounded like it was actually quite sturdy.
Unfortunately it would appear that I have lost the picture I took. If anyone knows the team that did this please post, they were in franklin I believe.
Unread 21-04-2008, 00:11
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
This looks like a really good start to a coaxial swerve drive.
However, I may offer some advice. One the swerve modules, you may want to consider using angle, C-channel, or a wider plate instead of the single 1x steel bar. The 1x steel bar will most likely flex somewhat, and without any sort of threaded beams (or something similar) between them to lessen the impacts of the flex, it may cause binding issues on the axles.
Art Dutra IV
世上无难事,只怕有心人.
pic: Coaxial Crab CraigHickman Extra Discussion 14 15-11-2007 16:44
pic: Vex Swerve Vince lau Extra Discussion 10 19-03-2007 10:08
VEX Swerve Drive Modules are Here! Chuck Glick General Forum 3 12-11-2006 21:40
pic: Vex Swerve v3 JVN Extra Discussion 22 08-09-2006 17:28
pic: Coaxial Swerve drive, lightened. CraigHickman Extra Discussion 19 22-06-2006 15:00
