Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Go Back   Chief Delphi > Other > Dean Kamen's Inventions
Unread 21-04-2008, 08:23
dunkonu dunkonu is offline
dunkonu is an unknown quantity at this point
Alternative abalancing mechanism
I am wondering is there a way to balance the scooter using mechanical parts?
Segway and other self-balancing scooter on the web uses gyro and accelerometer to balance the scooter but the problem is that they drain battery quickly.
If there is a way use gears or other mechanical parts to balance the scooter when it is at stop position, i believe the balancing scooter can run in longer time.
Unread 21-04-2008, 21:27
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Alternative abalancing mechanism
The gyro and accelerometer draw milliamps, virtually no impact on battery life.
The drain on the battery comes from the drive motors. Remove them and the segway will power on for weeks. But, it won't move (or it becomes a bicycle?)
Unread 22-04-2008, 01:15
yes yes, that's right.
When scooter is at stop position, the drive motors still rotate to keep balance.
I am wondering is there a mechanism like landing gear on the plane or a "leg" coming off from scooter when it is at stop position. When rider lean forward or backward, the "leg" retracts. the Maybe that can reduce a lot of power drain by the drive motors.
Unread 22-04-2008, 09:42
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
i'm almost sure theres a kick stand on the segway
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 22-04-2008, 16:03
Elgin Clock's Avatar
FRC #0237 (Black Magic)
There is, but it's only to be used when the operator is off of it for parking purposes. It's not strong enough to hold a person while in kickstand mode.
In fact, people have hopped on a Segway with the kickstand down, and snapped it off before.
Unread 22-04-2008, 16:30
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
I always thought you could lock the wheels on a segway and lean it against a wall. Never saw the kickstand...
Alternative education EHaskins Chit-Chat 11 10-05-2007 21:46
Alternative to limit switches? RbtGal1351 Electrical 27 10-12-2005 15:30
Alternative FIRST competitions Alex Burman General Forum 4 02-12-2005 08:51
alternative to futaba? dradius Motors 8 14-06-2005 03:35
Alternative Power Sources? plutonium83 Electrical 18 30-05-2005 15:09
