Go to Post I think that's what they think you will think, therefore you are thinking what they want you to think. - Wetzel [more]
Unread 21-04-2008, 20:44
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Re: pic: 2009 Control System, Mounted
Originally Posted by Alex Cormier View Post
So with all the talk about IFI going away, the new system comes in on a IFI kit chassis? My thought lately has been, will the kit chassis go away along with IFI?
I hope not...
*goes and starts to make numerous chassis in inventor/solidworks*
This bot was built using spare parts from FIRST's shop... It was only meant to be a sneak peak at the 2009 control system and in no way was meant to show what may or may not be in the KOP next year
So there may still be hope for the kit frame next year...
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 21-04-2008, 20:54
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
I'm not going to lie to you guys but the power block wire connectors are so strong that the people from Diversified Systems put batter wire on it and pulled a full size 120 lbs robot around without the wire pulling out. The wire was only a foot long, it was amazing.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 21-04-2008, 22:11
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
It's not the initial strength. It's the resistance to vibration. Since there's no WAY that thing could be any worse than the din rail (we zip tied the wires to ours so they wouldn't vibrate loose), then it has to be an improvement!
Unread 22-04-2008, 00:08
Originally Posted by Russ Beavis View Post
The long white module between the cRIO and PDB is an old rev of the Digital Sidecar (ie breakout module that allows cRIO to directly drive Victors, Spikes, digital I/O, etc).
That long module has already been replaced by the half-size module that's sitting next to the PDB.
Russ
Actually, the DSC3 is less than 1/5th the size of DSC1.
Originally Posted by Greg Marra View Post
How were the prototype white cases for the electronics components fabricated? They sort of look rapid-prototyped, but I am not sure, and didn't see them in person.
SLS
With a 6AWG wire inserted, I've dragged the robot several feet sideways (against the wheels) repeatedly.
However, smaller gauge wire does not have as much of a retention force. With a 12AWG wire, I only managed to move the robot a few inches. In fact, I could easily pull it out by simply wrapping it around my hand several times, giving it a few inches of slack and then yanking the giggles out of it. Unfortunately, I smacked my arm into the robot during said yanking. Ouch.
Don't count on those WAGOs on the PD as a structural element, but boy do I love them!
Unread 22-04-2008, 15:10
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
although it is a lot bigger than the IFI control system, who says that FIRST isn't going to allow larger robots, or even heavier ones? i really think robot design wont be the same any more.
Unread 22-04-2008, 15:25
Originally Posted by tseres View Post
...who says that FIRST isn't going to allow larger robots, or even heavier ones?
The robots are already about as large as they can be and still fit through a standard doorway. They are already about as heavy as they can be and still be carried safely by two high school students. I don't expect the size and weight limits to be increased. I wouldn't be surprised if the rules next year called for smaller robots.
Unread 22-04-2008, 15:35
Tapoore's Avatar
AKA: Tom Poore
The OSHA weight limit for a two person lift is 150 lbs. That is the real reason why FIRST can't increase the weight limit.
Unread 23-04-2008, 01:00
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
A robot with a battery and bumpers mounted could be up to 120 + 12 + 15 = 147 lbs. At least, that's if I remember correctly, and the battery weights about 15 lbs. So I don't see much room to add weight, if we wish to remain within OSHA regulations.
Unread 01-05-2008, 19:02
sayso_411's Avatar
sayso_411 sayso_411 is offline
10 Years of Sparky!
AKA: Shaav
FRC #0384 (Sparky)
sayso_411 can only hope to improve
I thought the distribution block/fuse block length was customizable, i dont wanna waste all that space that could be used for something else...
NEW 2009 Control System Released qnetjoe FRC Control System 296 15-08-2008 15:02
2009 Control System Possibility? Racer26 Rumor Mill 121 25-04-2008 09:05
New System for 2009 Lafleur Programming 1 17-04-2008 21:45
pic: Team 116 Modular Control System dlavery Robot Showcase 42 21-10-2007 11:15
2009 control board? Stuart Rumor Mill 4 14-05-2007 19:01
