Go to Post It's the corollary that you pick them no matter what shape they start the event in. Pink is known for showing up at their 1st regional with the robot in an unfinished state. And somehow, magically by the end of qualifications it just works, and they win. - Nuttyman54 [more]
Unread 21-04-2008, 21:19
Billfred's Avatar
Billfred Billfred is offline
pic: 2009 Distribution Block
Unread 21-04-2008, 21:21
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Re: pic: 2009 Distribution Block
ok so as I understand it the small, apparently unused white box thing mid left is the new and improved version of the clunky large thing on top? to clarify, will we still have to fit that giant thing on top on our robot?
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 21-04-2008, 21:26
pufame's Avatar
pufame pufame is offline
FRC #0291 (CIA)
Team Role: Webmaster
pufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud of
I think this distro block system so much better than the current
Power distribution + 20A fuse block + 40A fuse block
And, I like the way the wires connect in, less crimps/terminals the better
Unread 21-04-2008, 21:48
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
No. the long white breakout board at the top of the picture is just the 1st generation prototype of the FPGA/ Digital Sidecar and will not be in the 2009 KOP. The smaller board on the left is the 2nd generation Digital Sidecar and is similar to what will be in the KOP. Teams will probably be allowed to use two Digital Sidecars on their 'bots. The only reason why we used the larger board on this robot was that the smaller board didn't have a working firmware image when the 'bot was crated up for ATL.
The large PDB in the center of the picture will be included in the KOP, but as pufame said, it simplifies the power electronics system hugely.
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 22-04-2008, 09:54
Racer26 Racer26 is offline
My thoughts on it are this:
I like it, but I don't want my connections rattling loose. Also, 8 40A terminals... could FIRST be planning to let us use more big powerful motors? Otherwise, we have no need for >4 40A circuits.
Unread 22-04-2008, 10:08
If you think your connections are going to rattle loose, you have another think coming.
Unread 22-04-2008, 10:15
Well, we were by no means the only team that had the current PDB continually throw wires on us, though for 2008 we came up with a way to make it literally impossible for the wires to come out of it.
Unread 22-04-2008, 10:20
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
The connections on the new PD are nothing like the ones on the rockwell block - they are not set screw terminals but rather Wago terminal blocks. They are hard to describe - but essentially you stick a screwdriver in and lift to make a place for the wire to go, and then it springs into locked position when you remove the screwdriver. I don't know the exact spec but after playing with them I would imagine you can pull with 50+ lbs of force on a 12ga wire and not have it come out.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 22-04-2008, 10:56
Billfred's Avatar
It's been a possibility in the past; consider 2006 or 2007, where we had four small CIMs, two large CIMs, and two Fisher-Price motors.
Unread 22-04-2008, 11:14
EricVanWyk has said in another thread on this subject that he pulled a robot sideways by a wire in the block. Good news for all teams that had problems with the Rockwell block, I think.
Unread 22-04-2008, 12:11
Indeed Eric, I mistakenly thought these were screw type terminals. That makes me happier. No particular offense to Rockwell as some of their products are excellent, but those blocks were simply not designed for use on something that moves.
Unread 22-04-2008, 12:14
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
I agree. This is a much better system than the distribution block + 2 fuse panels. It may or may not make your space more efficient. I'm not sure yet.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 22-04-2008, 14:33
kborer22's Avatar
kborer22 kborer22 is offline
kb
AKA: kb
FRC #0125 (Nutrons)
kborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud of
Send a message via AIM to kborer22
this is one of the features that i am most looking foreward to in the new control system, this is circa 2005 when IFI created something very similar to this. I think it had 6 40A sports and something like 20 slots for 20-30A, it was amazing and i was sad when they took it away. I HATE the Din block that we have now, i could never seem to get the wires to stay in there, and in 2007 actaully shorted the block and melted it. Now that FISRT does not have to please MAXI with that seperate 40A panel, this will really help to centralize everything on you robot, once again EVERYTHING can come into the same place, good work first!
(upper portion of the picture)
http://www.chiefdelphi.com/media/photos/23327
NUTRONS 125
2007 Boston Regional Champs (125, 126, 69 NU-Hyper-Force!)
MORTTeam 11
2004-Palmetto Regional Champs
2004-Palmetto Regional Daimler Chrysler Team Spirit Award
2005-NJ Chairman's Award Winner
Unread 22-04-2008, 15:45
Again, just because I can do it doesn't mean that you _should_ do it. Its like throwing the cRIOs - Will they survive? Yes. Should you do it? No.
Unread 22-04-2008, 15:48
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
There is plenty next years RC and electronics can do that I think will probably be limited by rules at FIRST. Sure we have access to ridiculous amount of input/outputs and 8 40amp fuses but it is likely the rules will limit us the next few years. It is obvious they wanted to design a system they could scale up to.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
distribution block Magnechu Electrical 11 14-02-2008 19:07
Distribution Block Magnechu Electrical 3 04-02-2008 21:38
Power Distribution Block.. beemgruem Electrical 21 11-01-2008 08:11
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
