Go to Post Never underestimate people's ability to underestimate. - Ginger Power [more]
Unread 22-04-2008, 18:37
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
"mouse encoders"
I know it’s possible to convert an optical computer mouse into an optical encoder that you can mount on the bottom of your robot to tell how far you've gone, but I can’t seem to find any mouse sensors fast enough. (The fastest I've found has a top speed of about 5 ft/sec.) Is there any pre-existing encoder that functions like a mouse, or any optical mouse hack that would achieve a sufficient speed to go on a FIRST robot?
Unread 22-04-2008, 18:53
Joining the 900 Meme Team
FRC #0079
Re: "mouse encoders"
What about actually using a ball that ran on the ground to "gear down" the speed you are moving at. I think that would work... either that or a series of balls to do it. I cant say how efficient that would be.
As for a larger version of that system I cant say.
Unread 22-04-2008, 18:57
Jared Russell's Avatar
Taking a year (mostly) off
I've thought about this before, and ran into the same problem that you described. Commercial mice are just not made for high speeds. Can it be done? Sure - but you will need a lot of expertise on the subject, not to mention the ability to fabricate optics.
I am, however, working on something similar for next years' control system using optical flow navigation from a downwards-pointing digital camera. With the processing power of the cRIO, it might just work. Basically, you take a picture of the carpet, then another picture a fraction of a second later. You can solve the optimization problem to determine the vector relating the movement between the two shots. At a high enough speed (I'm hoping for 15-30Hz), you can essentially get optical mouse-like results.
nickmagus's Avatar
AKA: Nick Clayton
That could work but it might have slop or break if it hit a piece of debris on the field. Thats why I was hoping to avoid contact in the first place.
Unread 22-04-2008, 18:58
I think he was talking about using an optical mouse. Ball mice can work and I've seen them on robots with some modifications.
Unread 22-04-2008, 19:00
nickmagus's Avatar
AKA: Nick Clayton
That was the other option I was considering however given the proximity of the camera to the ground if its on the bottom of the robot wouldn't the size of the picture be so small that the next frame could have none of the old picture?
Unread 22-04-2008, 19:02
FRC #0079
I know, I was thinking read the ball, truth be told, that might help you with your camera thing, keep the issue of field debris away. Just put a fine checkerboard pattern on the ball and go from there.
Unread 22-04-2008, 19:05
nickmagus's Avatar
AKA: Nick Clayton
ya that could work i wonder if its possible just to avoid the ball all together though. That would be ideal.
Unread 22-04-2008, 19:21
Gdeaver Gdeaver is offline
FRC #1640
A couple of years ago some people looked into this. There are gaming mice that are fast enough. The problem is optics, illumination and the fact that optical mice are designed to work best on a laminate surface. Avago holds most of the patents on the algorithms used to detect the movement and are suing a bunch of other chip companies. Using a 1/2 VGA camera could work if you got the focus and lighting right. Then you would have to develop the algorithm and have enough processing speed. The good algorithms are closely guarded IP.
Unread 22-04-2008, 19:56
I need to warn anyone thinking of using a "telephoto mouse" or camera system of a real problem. The field of view, and thus the relationship between image motion and actual velocity, changes with height from the floor. Any bouncing of the system, or even significant vibration, will throw off the results.
Unread 22-04-2008, 20:15
martschr martschr is offline
FRC #2461 (Metal Skins)
martschr is a glorious beacon of lightmartschr is a glorious beacon of lightmartschr is a glorious beacon of lightmartschr is a glorious beacon of lightmartschr is a glorious beacon of lightmartschr is a glorious beacon of light
Same thing for us.
We tried the optical mouse thing only to find out they are too slow. Instead we put encoders on omni wheels to accomplish the same task. One encoder for x axis and one for the y axis. It was accurate and accomplished our task. The only problem was by the end of everything the rollers in the omni wheels (ones for VEX) were not turning very well because of cuts and scrapes.
Unread 22-04-2008, 21:08
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
I think a vision-based system (ie, optical mouse/camera) is probably more trouble than it's worth. As Mr. Anderson said, the potential for error due to vibration/bumps is pretty high (try bouncing your optical mouse and see what your cursor does).
MORT has used these on our drive shafts, and they don't seem to be a problem. Naturally, any time the wheels slip, there is slop.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 22-04-2008, 21:38
With a good Kalman filter, the optical flow path can work quite well. I've done it before.
Is it worth the trouble? Probably not But yes, it can and does work when well-implemented.
Unread 22-04-2008, 21:54
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
This approach is used by Team 16, the Bomb Squad...
(Photographic illustration of martschr's post above)
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Last edited by David Brinza : 22-04-2008 at 23:23. Reason: Somehow missed martschr's post...duh
Unread 22-04-2008, 22:17
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
Originally Posted by David Brinza View Post
Or how about this approach used by Team 16, the Bomb Squad?
That's what I suggested when Nick asked me about it after school today
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
