Go to Post How many computer programmers does it take to screw in a lightbulb? Woah, no. That's a hardware problem. - jordie228 [more]
Unread 23-04-2008, 11:52
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Pressure Switch
Does anyone know where to get a pressure reader for the control box.
R.C.
MadTown Robotics Team 1323
Unread 23-04-2008, 16:48
Racer26 Racer26 is offline
Re: Pressure Switch
Do you mean a pressure transducer, such that it converts the air pressure into a voltage, which you can feed back to the Robot Controller, and read out on the Operator Interface? If so, you can find one in the 2004 Kit of Parts (I believe 1323's rookie year was 2004, otherwise, you may want to locate a nearby team with a team number less than 1200, they should have one.)
Unread 24-04-2008, 00:13
R.C.'s Avatar
Re: Pressure Switch
Yes, but where can you order one.
Thanks, rc
R.C.
Unread 24-04-2008, 01:54
dtengineering's Avatar
AKA: Jason Brett
Re: Pressure Switch
Digikey has a range. For the High Pressure side of the system you might consider http://search.digikey.com/scripts/Dk...me=223-1014-ND for about $130
While for the low pressure side something like this http://search.digikey.com/scripts/Dk...me=480-1922-ND might be more affordable. $25 or so.
I would do a careful search, however, of all the pressure transducers available on digikey, and take care to read their data sheets. I've just picked these two out as possible examples and HAVE NOT confirmed either that they would be FRC legal (whether you care or not...) or otherwise a good choice for your application.
Jason
pressure switch M.Jesus Pneumatics 2 16-02-2008 16:23
pressure switch M.Jesus Pneumatics 1 15-02-2008 17:36
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
