Go to Post I think I speak to everyone who ever attended nationals there when I say...say it with me..."Please stand clear of the doors. Por Favor Metengan se alijados de las puertas." - Justin [more]
  #46   Spotlight this post!
Unread 24-04-2008, 01:30
mcf747 mcf747 is offline
AKA: Matthew Forman
FRC #0190 (Team 190)
mcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud of
Re: Silly Programming screw ups (funny)
2008:
I am hooking up the electrical and working with our programmer to well drive the motors im hooking up.(the two window motors keyed together). Any way we have a button set to automatically shoot the ball out of the arm and then drop the arm to a position where it can pick up a ball again. At our first regional we end up inverting the position of our window motors and go out to another practice match. We start the automatic sequence and bang the arm drives backwards and fold over itself crashing into the back of the robot. We cant figure out what happened but I think it was the recoil from the punch so i tell our drivers to not raise the arm so high when they fire it and in the next match it does the same thing. We put a hard stop, using steel wire, on it as the arm was "pushing" through the stop sensor think this would stop the recoil. We send it back out and it happens again and then i remember that we never reversed the code when we inverted the motors, and the powerful worm drives pushed through our hard stop and the delay was to great from the senors that the arm was already more than half way over when the arm lost its momentum, crashing down anyway due to gravity.
What we learned:
-Two worm drives are no match for a 20G steel cable
-Remember to check code after inverting ANYTHING
-Built a robot so tough it can handle major abuse to cover for the occasional mistake
Matthew
MorTourq 1515
  #47   Spotlight this post!
Unread 24-04-2008, 03:12
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
In 2001 I was trying to write a program to automatically balance the bridge (which was basically a big see-saw) with our 2000 robot and a gyro. My first idea was to have it slowly drive up the bridge until it sensed rotation, then have it reverse proportional to the gyro input. Unfortunately I got the gyro input backwards, and as the bridge started to tip instead of reversing the robot began to accelerate. The faster it tipped, the more it accelerated. Fortunately the bridge and the robot came crashing down on the other side before the robot could launch itself off the end or else it would have really caught some air.
  #48   Spotlight this post!
Unread 24-04-2008, 07:37
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Originally Posted by mcf747 View Post
What we learned:
*chuckle* I guess you didn't need MorTorque.
Back when we were using a toughbox transmission at the Midwest regional, the 36:1 -> 12.75:1 reduction from the dual FP motors was SO SLOW... but way way too forceful (it could lift the whole robot without breaking a sweat).
Well... and we found out on our practice bot that if it did break a sweat... it bent a 9" length of beautiful new 1/2" stainless steel shaft.
...After that we made a new single-reduction-stage transmission that saved weight and turned all that extra force into lightning quick arm speed.
-q
p.s. It never screwed up the right way in competition, but we found out that if you pick the ball up then hold the manual up button with only a few psi of air in the system... the ball flys out and actually goes high enough to hurdle over the back of the robot with a perfect shot.
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
  #49   Spotlight this post!
Unread 24-04-2008, 13:26
bcieslak
Posts: n/a
Talking Re: Silly Programming screw ups (funny)
Originally Posted by tseres View Post
this is kind of a funny thing. you see, on our team, everything is the programmers fault, no matter what. it's the way it is. i'm the programmer. we had the robot ready to test, and we powered it on, at which point it flew straight into a heavy table. it was "my fault". turns out another guy was getting ready to go and accidentally buy his backpack on the xbox controller
You see FIRST really does prepare you for a professional career in programming. I've been a systems programmer for 20 years and every time something goes wrong its my fault. Then I spend a week proving its not...And even though its a hardware problem I am expected to write code to fix it. Thats because software is free, you can't touch it or see it. When I come into work no says 'good morning', they say 'you have a software problem.'
But the load of money they give me makes up for it.
Just imagine what its like to be a programmer on my teams.
BC
Programming Mentor
Team 1675, 1714
  #50   Spotlight this post!
Unread 24-04-2008, 13:32
bcieslak
Posts: n/a
You know those lines in the code that say
/* Do not remove */
They really do mean it.
that became evident when we accidentally deleted a line in the autonomous code and the robot sat through a whole match.
BC
Programming Mentor
Team 1675 , 1714
  #51   Spotlight this post!
Unread 24-04-2008, 15:59
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
2007:
Team:"Can you make the robot drive forward for two seconds after unfolding the arm?"
Programmer:"Sure, that's easy!"
Match starts... and the robot careens into the opposite wall!
Programmer:"Well, you didn't remind me to stop it!"
We were on the ref's watch list for the rest of the event as we later found out.
Because of this incident, every time we change the autonomous, everyone asks if it stops when it's done.
  #52   Spotlight this post!
Unread 24-04-2008, 16:03
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
Originally Posted by BigJ View Post
2007:
Same thing happened to me this year during build season. Except when I did it, the laptop was still plugged in, and I had to run after it until it went through 2 stools, a table, and finally hit the wall. Luckily the arm wasn't deployed.
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
  #53   Spotlight this post!
Unread 24-04-2008, 16:15
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
This one reminds me of Zoolander:
On our scrimmage bot from the summer we broke a banebots 56mm drive transmission due to over-agressive driving and direction changes. Since we didn't want this happening to our expensive new AM shifters, the coding team implemented a "soft steer" drive that limited how fast the robot could change directions for the '08 season. They had limited testing due to unforseen and unavoidable build-team delays.
We get to VCU in week 2 and all of a sudden the robot can't turn left in teleoperated mode! This was the cause of most of our penalties at VCU. All our driver could say was "I don't know, don't blame me, I'm not an ambiturner!". We commented out that portion fo the code Friday night and BAM it could turn left.
GitHub
  #54   Spotlight this post!
Unread 24-04-2008, 16:32
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by Alan Anderson View Post
This line of code was inserted into a file which contains prominent warnings that it is not to be modified. Some of us programmers know the reason for the warnings, and know that some modifications are "safe". We just fail to clean up after ourselves sometimes.
In my line of work, we affectionately refer to this approach as "Seagull Engineering". Why? Because we swoop in, flap around making a lot of noise and commotion, leave a big mess of "stuff" behind and then fly off. (You can substitute your own words in for "stuff" ) No one really knows what we did or what happened.
  #55   Spotlight this post!
Unread 24-04-2008, 18:05
11Mort11's Avatar
11Mort11 11Mort11 is offline
AKA: Alex Joss
FRC #0011 (MORT)
11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold
Send a message via AIM to 11Mort11
mecanum drive code in a tank drive robot
bad things happened
  #56   Spotlight this post!
Unread 24-04-2008, 18:14
AdamHeard's Avatar
Lead Mentor
For future reference, you can run the AM shifters HARD without issue.
  #57   Spotlight this post!
Unread 24-04-2008, 18:21
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
Originally Posted by Cow Bell Solo View Post
Saying it's Programmings Fault is a viable reason for everything, EXCEPT THE ROBOT FALLING APART
Hmm, I've got a lot of funny stories on that, but my favorite has to be the elimination match when instead of the usual routine of driving forward to get line-crossing points, our robot promptly spent its hybrid mode driving in circles. Of course, I got "the look" from several members of my team, until I looked under our robot afterwards and pointed out the wheel resting diagonally between two pillow blocks.
One instance where it was my fault: half the team was struggling along with me to discover why no Victor we threw at our proto board would drive a motor. What I eventually realized (and of course, failed to tell them), was that I still had the joystick values overridden to neutral whenever a rangefinder read less than 6 inches.
The rangefinder was unplugged, thus "reading" 0 inches.
  #58   Spotlight this post!
Unread 24-04-2008, 21:49
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
Another funny one I got is when in autonomous, this year, we were in a practice match in the regionals at L.A. and it was the first time we were going to test autonomous, my autonomous was just said to drive straight, but what I forgot was that one wheel rotated faster then the other, and in my autonomous code I had the robot going full speed. So autonomous starts, and the left motor goes super fast, and the right goes semi fast, and it veers and hits the center divider really hard. Teleop mode starts, and our driver can't start the robot, we go down to check it out after the match, and the battery cable had come unconnected, as well, as other cables, all because of my autonomous, boy did I get yelled at after that.
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
  #59   Spotlight this post!
Unread 02-05-2008, 23:48
Eric24's Avatar
Eric24 Eric24 is offline
FRC #1138 (Eagle Engineering)
Eric24 is an unknown quantity at this point
Send a message via AIM to Eric24
Today at the Vex Championship we added two extra motors to the arm, so I was programming autonomous quickly and forgot to add the stop to those motors. It ended up that the arm flipped over backwards and we actually scored because the arm dumped all the balls into the bridge backwards. Everyone was so stunned since that was never the intention of the program. It was the most amazing autonomous ever!
  #60   Spotlight this post!
Unread 03-05-2008, 00:06
Are you keeping that "bug"?
pic: I Love UPS! dubious elise Extra Discussion 15 05-05-2006 16:43
pic: UPS with UPS Kevin Kolodziej Extra Discussion 10 04-05-2005 12:57
I am silly. FotoPlasma Chit-Chat 15 07-01-2003 09:55
silly fun Mark Hamilton Chit-Chat 8 29-10-2002 13:56
