Go to Post “I hope you all had a good weekend. If you didn’t you can try again in five days.” -Honors Debate teacher - Joe J. [more]
Go Back   Chief Delphi > Technical > CAD
Unread 23-04-2008, 22:29
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
Autodesk VIZ help!!
I am a newbie to autodesk viz and 3ds max. I have been trying to make a simple arena and robot from this years game just to try to get started. I have made the arena and robot. I have a problem with the animation part, heres the scenario, i want to animate the robot to drive straight and then turn left, but whenever i try to do this the robot seems to be turning and going straight at the same time, so what do i need to do in order for the robot to drive straight THEN turn left?
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 24-04-2008, 13:35
richalex2010 richalex2010 is offline
AKA: Jake Alexander
FRC #0177 (Bobcat Robotics)
richalex2010 will become famous soon enough
Re: Autodesk VIZ help!!
Sounds like you need more specific keyframes (assuming that's what you're using, and not Reactor). You have to set keyframes for everything you're animating, including rotation and direction, for the duration that it's being animated (otherwise it will remain at the previous keyframe).
By the way, there's a separate forum for this in the IT/Communications section (3D Animation and Competition).
-Jake Alexander
Autodesk 3ds MAx help Mrtrom 3D Animation and Competition 1 12-01-2008 23:05
Need Autodesk Help!!! Setsanto 3D Animation and Competition 7 19-01-2007 10:18
viz 2006 plant downloads trout2007 3D Animation and Competition 2 17-12-2005 08:11
Autodesk GMAX Help/Tutorials sanddrag 3D Animation and Competition 2 02-10-2005 08:48
VIZ Emergency Jeremiah Johnson Inventor 4 22-01-2005 19:55
