Go to Post It's only messy if you allow it to be. - Jay H 237 [more]
Go Back   Chief Delphi > Other > Math and Science > NASA Discussion
Unread 25-04-2008, 06:56
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Glitch worsens on Mars rover's robotic arm
OH NO.... Opportunity's needs a time out.
http://www.msnbc.msn.com/id/24300717/
Unread 25-04-2008, 08:09
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Glitch worsens on Mars rover's robotic arm
Seeing as they're on their 17th lifetime, a few glitches like this would be expected.
And since there's no 80" cylinder on Mars, there should be no problem leaving the arm extended.
(since 2004)
Unread 25-04-2008, 09:44
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
pssshhh... Gaint Pistons always work! (our last two robots have had giant pistons )
Unread 25-04-2008, 12:05
Not enough air on Mars.
Did Spirit and Opportunity fit into the cylinder in the first place?
Unread 25-04-2008, 12:25
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
There isn't???!?! Gee, that will be a real surprise to all the atmospheric scientists working on the project.
-dave
Unread 25-04-2008, 12:29
-dave
How much air is there (compared to earth)?
Unread 25-04-2008, 12:50
dlavery's Avatar
Curmudgeon
Depending on the season, latitude, and altitude, the average surface atmospheric pressure varies between 6 and 9 millibars.
It may not seem like much (it isn't), but the Martian atmosphere is more than dense enough to allow effective use of parachutes during the entry-descent-landing process by multiple spacecraft.
And, yes, pistons will work just fine on Mars.
-dave
Unread 25-04-2008, 15:00
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
There was a compressor developed for Mars with no moving mechanical parts (other than valves to control the flow of ambient and pressurized gas). Overnight (when it's cold) carbon dioxide is adsorbed in a porous material inside a pressure tank through a valve open to the Mars atmosphere. During the day (when it's warmer and electrical power from solar arrays is available) the valve is closed and heaters are used to drive off the CO2 from the adsorber. Pressure in excess of one Earth atmosphere could be produced this way. This concept was developed for an experiment intended to demonstrate the production of oxygen on the surface of Mars.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Dean Kamen's..... ROBOTIC ARM? Joe Matt Dean Kamen's Inventions 15 24-02-2010 08:47
Programming a Robotic Arm harriton Programming 3 20-03-2007 12:42
OWI Robotic Arm cvhsrobotics Technical Discussion 2 18-01-2005 00:34
Robotic arm joints Collmandoman Technical Discussion 2 17-01-2005 23:23
pic: Robotic arm CD47-Bot Robot Showcase 2 14-09-2003 17:37
