| Thread Tools |
Rating:
Display Modes |
#241
Re: NEW 2009 Control System Released
In other words, LV will not prevent you from writing code that operates inefficiently. The compiler will do what it can to improve things, and as in any language recognizing and measuring what code is doing takes consistency and practice. One benefit to rapid development languages like LV is that while the array insertion code your fellow student wrote wasn't optimal, it sounds like it did work. If a non-CS user is able to get valid results from their computer, that is a huge improvement over what they could often achieve with a language that gives them super low level control. Hopefully when the time comes for optimizing, they are then able to keep the correct results as they experimentally modify their implementation. If you have further questions about how LV implements its voodoo, both the NI LV forum, and now this forum are a great place for it to take place. Greg McKaskle |
#242
I keep seeing a lot people of keeping talking about how the FPGA is off limits. I really don't think that FIRST would go that far, because without access to the FPGA what is the real benefit of the new controller?
I would take a guess to say that there will be a custom VI that allows us to tailor the use of the FPGA while allowing FIRST to maintain their required supervisory control. I have done things very similar to this with my cRIO's and PXI chassis with RT controllers. For years with FIRST safety has only been skin deep. Change a few registars from any of the 2004-2007 controllers and your robot can be really dangerous. Besides you have 20 engineers at FIRST/NI vs a FRC community of 20k with a passion for this stuff. We WILL find a way to program that FGPA. Last edited by qnetjoe : 24-04-2008 at 23:37. |
#243
They said for the first year it would be off limits. After that its fair game, unless I heard wrong. |
#244
![]() Didn't I warn you not to talk like this in public Kevin? ![]() |
#245
One brain blip I had in regards to above was that there wouldn't necessarily be just ONE FPGA programmed image to choose from - after all this is field programmable. In that case, much like configuring a work truck you'd choose from one of a number of standard FPGA setups provided. There are only so many digital input lines to choose from after all, so how you dedicate them to what sensor suite may be selectable. That is, one image supports 6 encoders plus other stuff and another supports only 2 encoders plus other things. With multiple FPGA images provided the likelyhood of finding one close enough to match the robot you want to design becomes greater. Quote:
Don't take this the wrong way -- just after 30 years of systems engineering at the s/w-f/w-h/w boundary this statement quietly screams "WATCH OUT!" One way of interpreting this comment is that FIRST will be the beta test customer for using C/C++ to program the cRIO. From a product roll-out risk perspective, things just got a whole lot more interesting. Last edited by dcbrown : 25-04-2008 at 12:07. |
#247
overwrite your tether and automous registers and IFI controller will function without any supervisory control. You can use the live debug feature inside of MPLAB to find these
#248
Of course, this is something that is subject to change in future versions of the VxWorks port for cRIO, but it's most likely not going to happen in even the next major release. -Danny Last edited by Danny Diaz : 25-04-2008 at 12:44. |
#249
Have you actually tried this? I'm guessing not, because that won't work. Please, if you disagree, I dare you to prove me wrong. Post a video or something. IFI designed a superb system from a safety standpoint - it's basically impossible to override the safety features through anything you can do on the User processor. After many years of studying the details of the IFI design, it is very, very obvious that safety was a top priority in their system. Field reset crews, referees, and match announcers can step on the field with confidence knowing that if the control system has the robots disabled, they will really be disabled. I certainly hope as much care is being put into the safety features of the new system as IFI put into theirs - it's not a good thing when a 130lb machine moves when you think it's turned off. |
#250
Off-topic for the thread, but still worth mentioning...
While I'm sure the new system is going to be just as safe as the old one, it's going to be just as possible to bypass the safety features with illegal wiring. Fortunately, that sort of thing is not hard to catch with a visual inspection. |
#251
Luckily, it is (in my opinion) still much easier to catch wiring errors than coding errors... and that will be more true of the new system (basic rule of software engineering: as system complexity increases, so do the odds of having bugs). |
#252
I too would love full access to the FPGA, but that may be impossible. Here are some ideas that may give us more freedom even with a locked down FPGA.
For example, assume you have a black box that performs the signal processing on one encoder input. Now, stick a mux in front of it and feed every digital input into the mux. Then, use the RTOS to fill an array of registers with the inputs you want processed and one final register with the number of entries in the array. Then just start a counter to iterate through the array and feed that into the select pin on the mux to process each input one-by-one. Oh and you'll probably want a demux on the other side so the encoder count sum goes to the right place. I'm sure there's a more efficient way of doing it than the way I've described, but I was trying to keep it conceptually simple. [Edit]: Come to think of it... this won't work too well, but I think the idea may be feasible. Can anyone fix it?[/Edit] [Edit2]: Each pin that can be configured as an encoder will need to have its own state (count sum). The only thing they might be able to share is the combinational logic, but it takes basically no CL to count an encoder, so there's really no point.[/Edit2] Last edited by Jay Lundy : 25-04-2008 at 15:58. |
#253
The other solution is to hard code in X encoder counters, and Y GTS counters and Q other devices, spread across the digital input lines as widely as possible, but each dedicated to a particular port, much like the different peripherals on the PIC. Then have various enable/disable lines to select which ones you want to use as GPIO and which to use as peripherals. Maybe you could even have various bits to twiddle on and off to select slightly different functions for the various modules or otherwise modify their operation. You could even have a few registers here and there to further tweak the function of the various peripheral modules. I bet if the NI/WPI guys work hard enough they could come up with the equivalent of, ooohh, three PIC18F2431 chips (only $3.07 per!). Which is to say that if we wanted a large amount of flexible hardware based IO that we could simply turn on and off with the flick of a switch, a controller based on a local net of microprocessors might have been a better move. The whole point of an FPGA is that you only have to implement what you need and it can be whatever the heck it is you want. So I hope the various people involved in the control system understand our frustration with paying more for a new controller that we don't have yet and will quite likely lock us out of the single most useful feature it has. Last edited by Kevin Sevcik : 25-04-2008 at 16:52. |
#254
The FPGA on the cRIO is an open LV target. This means that LV code can be designated to run on the host PC, the PPC, or the FPGA. Of course LV targets the FPGA via VHDL, and therefore the cRIO is ultimately targetable with C-based .out PPC files and bitfile produced from VHDL. To promote a migration path, promote working, stable robots, and ensure safety, the decision was to keep the FPGA closed for at least the first year. After that, depending on how things go, it could be opened to the extent that there are vanilla, chocolate, and rocky road flavors. It could be opened further by providing 09 source and allowing teams to go nuts. Technically, these are all possibilities, and it is a policy decision as to what makes the most sense for the organization and competition. At this point, I'm sure FIRST is listening, but any opinions you may have honestly aren't well founded. After a season, the feedback will carry much more weight. As for the SW stack required to peek and poke. I'm not entirely sure, as this isn't something I've used much directly. The success of the product is hinging on the performance of said calls, so I'd say that it is probably pretty performant and more importantly, deterministic. Moving forward, I will be happy to get the gory details for those who are curious about how it works. But for now, I think you can trust that the FPGA is not using dev/IO, and is instead a low-level custom driver. Greg McKaskle |
#255
Respectfully, I honestly don't think your opinions are well founded either. There are at least a few people in this thread that have experience with the cRIO platform. I personally have experience a PXI-RT/FPGA platform. The project I was discussing earlier was a graduate level project. I managed to use 32-bit Q-Math to cram the entire forward kinematics of a 3-DoF PHaNTOM haptic device on to a 1M gate FPGA, including the interface logic for my quad encoders, logic for virtual walls and the transverse Jacobian to translate my Cartesian forces back into joint space. If you're not familiar with robotics, that's, basically, one-half to one college ruled page of trig dependent non-linear equations. I've also been working with the C-based IFI controller since its inception. So I hope you believe that I might have some clue about this. So, I think it was a valid opinion that it would be highly annoying to be forced to interface with custom sensors or encoders using fixed rate sampling or interrupts on the cRIO processor. My annoyance is based strictly on my personal dislike of compensating for hardware deficiencies in software AND NI's own literature lauding the flexibility and utility of this wonderful hardware that we're not going to actually be able to use, so I feel it's valid under the circumstances. I'll note that at the last control system change-over, we were given free reign over all the hardware on the PIC. The annoyance there was simply that so much of it was blocked off by buffers and other things necessary for safety. I will agree that any opinion on how things will turn out in the 2009 season is entirely premature. However I think this is primarily because of the distinct lack of information available to us right now. The fact that the nature and utility of the FPGA code is still undetermined frankly makes me nervous. The fact that the development environments are still under development highly worries me. I do appreciate your willingness to discuss the nitty gritty of the RTOS and such with us, but since we don't know what sort of high speed or interrupt based processing we'll be needing on the RTOS nor what the structure of the code will be, I don't think I can ask any intelligent questions. I think a lot of this angst and annoyance could have been taken care of if this system was closer to a prototype of the system going out to teams and farther from a demo piece put together by NI to sell us on the system. I know I would have been fine with more man hours spent on these TBD features and less man-hours spent on a pretty holonomic robot with a sponge canon and flashy interface that still on bears a resemblance to the environment and hardware we'll be working with. |
| Buying the 2009 control system | BornaE | FRC Control System | 9 | 16-10-2008 17:16 |
| 2009 Control System Feature Wishlist | tdlrali | FRC Control System | 47 | 17-06-2008 00:25 |
| pic: 2009 Control System, Mounted | Billfred | FRC Control System | 23 | 01-05-2008 19:02 |
| 2009 Control System Possibility? | Racer26 | Rumor Mill | 121 | 25-04-2008 09:05 |
| Forum Request: Post-2009 control system? | Billfred | CD Forum Support | 3 | 22-04-2008 16:22 |
