Go to Post "So [you're] like battlebots" Standard answer: No -- it's better! - Roger [more]
Go Back   Chief Delphi > Other > Math and Science > NASA Discussion
Unread 25-04-2008, 15:00
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Glitch worsens on Mars rover's robotic arm
There was a compressor developed for Mars with no moving mechanical parts (other than valves to control the flow of ambient and pressurized gas). Overnight (when it's cold) carbon dioxide is adsorbed in a porous material inside a pressure tank through a valve open to the Mars atmosphere. During the day (when it's warmer and electrical power from solar arrays is available) the valve is closed and heaters are used to drive off the CO2 from the adsorber. Pressure in excess of one Earth atmosphere could be produced this way. This concept was developed for an experiment intended to demonstrate the production of oxygen on the surface of Mars.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Dean Kamen's..... ROBOTIC ARM? Joe Matt Dean Kamen's Inventions 15 24-02-2010 08:47
Programming a Robotic Arm harriton Programming 3 20-03-2007 12:42
OWI Robotic Arm cvhsrobotics Technical Discussion 2 18-01-2005 00:34
Robotic arm joints Collmandoman Technical Discussion 2 17-01-2005 23:23
pic: Robotic arm CD47-Bot Robot Showcase 2 14-09-2003 17:37
