Go to Post In all seriousness, here's a thought for everyone: Don't worry about what you can't control. - Rich Kressly [more]
Unread 21-04-2008, 22:55
Los Frijoles's Avatar
Los Frijoles Los Frijoles is offline
Stormin' Mormon
AKA: Kevin Cuzner
FRC #2062 (C.O.R.E.)
Los Frijoles has a spectacular aura aboutLos Frijoles has a spectacular aura about
Send a message via AIM to Los Frijoles
Psuedorandom numbers
Well I have been studying psuedorandom sequences for Microchip microcontrollers based on seeds and so far the fastest I have found is thusly from mondo technology:
chop    movf    val1,w     ;get the 1st
        addwf   val2,w     ;add the 2nd
        movwf   val2       ;store the 2nd
        addwf   val3,w     ;add the 3rd & store
        movwf   val3       ;back in 3rd
        addwf   val1       ;add back to 1st
        swapf   val1       ;swap nibbles
        movf    val1,w     ;return one byte
        ret
It looks to be 10 instruction cycles long. However, I would like to see some other methods as I have found that this particular algorithm tends to repeat numbers after a short while with only a 24-bit seed. Does anyone else know of some psuedorandom sequences (C, ASM, or Psuedocode please)?
Community Of Robotic Engineers 2062
Blender totally pwns 3DS Max...
My life is here and here.
Cuznersoft Hardware and Software Development
Unread 21-04-2008, 23:00
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Psuedorandom numbers
Quite a bit longer than 10 instruction cycles but here is what our prof made us use for a lab earlier this year:
static unsigned long int SEED_X = 521288629L;
// this is a 32-bit constant
static unsigned long int SEED_Y = 362436069L;
unsigned int random()
static unsigned int a = 18000, b = 30903;
SEED_X = a*(SEED_X&65535) + (SEED_X>>16);
// requires 16X16 multiply, 32bit add
SEED_Y = b*(SEED_Y&65535) + (SEED_Y>>16);
return (SEED_X + SEED_Y)/2;
// requires 32bit add, 32bit shift
We had to implement this in ASM for our Lab before we started C so I have an ASM implementation, if you want to see it PM me.
Unread 27-04-2008, 01:02
FRC #0701 (RoboVikes)
use a linear congruential generator - probably the best in terms of ease of use to simplicity ratio. It's on wikipedia
-Salik
Team 701
Rounding numbers teh_pwnerer795 Programming 13 17-12-2006 12:16
Negative numbers? Calvin Programming 6 09-02-2005 10:46
Part Numbers DDRAngelKurumi Kit & Additional Hardware 1 29-01-2005 18:38
pwm numbers CharlieWilken Programming 2 15-03-2004 01:15
Team Numbers archiver 2000 2 24-06-2002 00:24
