Go to Post Some people need the 2x4. - Ether [more]
Unread 25-04-2008, 10:46
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
pic: 1565 Linkage Troubles
Unread 25-04-2008, 10:48
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: pic: 1565 Linkage Troubles
Oooo, Oooo. Mr. Cotta, Mr. Cotta.
(Sorry, I'm probably to old for most of you to get the reference.)
Is it the "S" shaped link bar??
Unread 25-04-2008, 10:49
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Linkage arm is bent.
Linkage bolt is not perpendicular to the linkage arm.
Also, is it just me or does it look like the entire linkage piston is unseated?
GitHub
Unread 25-04-2008, 12:27
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Reminds me of when this happened at GLR to our robot.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 25-04-2008, 12:33
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Flat bars aren't very strong in compression...maybe try angle next time?
Unread 25-04-2008, 12:49
FRC #1360
So many people have said that to me at one point or another!!
Next time we will make sure that the outside frame doesn't get shifted (more bracing fixed the problem completely) lol. The flat stuff is strong enough, and only in that rare occasion would angled be nessacary. Unfortnatly angled pieces take up a lot of space. we may dimple them for next year though (raise the middle, so it is very slightly concave or convex)
JeeseK good work on the bolt!! The bolt is out of alignment because the two bars connected to it are also bent (just not nearly as badly as the long link )
Unread 25-04-2008, 12:53
MrForbes's Avatar
AKA: Jim
You could probably get away with cutting the flange off the angle for several inches at each end. The dimpled center idea is good too, if you can figure out an easy way to do it. This is pretty common in linkages on real life machines (for example the flat bar that connects the inner door handle in a 1950s chevy).
Unread 25-04-2008, 12:57
FRC #1360
lol.. seems like we found that dimple idea from somewhere eh??
Unread 25-04-2008, 14:28
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
In our shop we have what looks like an ancient machine that will put a big long dimple down the middle of sheet metal and such, a bead roller. we used it on paper thin and flimsy lexan in '06 and it seemed to work really well at giving some added strength.
Unread 25-04-2008, 14:38
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Ya that looks pretty nasty. I wish I had a picture of the 3/8ths aluminum bolt we broke in half at champs and the welds that broke off our elevator bearing holder tabs the very first qualification match of the day on Friday. Quite funny stuff looking back at it now, not so much at the moment though. I hope you guys got everything up and running and were able to over come that little bump it looks like you took.
-Good luck
Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 25-04-2008, 14:57
FRC #1360
we managed to fix the linkage in about 10 mins lol flat bar is plentiful so we just made a new one!!
Unread 27-04-2008, 12:13
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Bummer, that is a real problem....
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 27-04-2008, 12:32
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I would defiantly recommend getting some sort of bend in that flat bar, or replacing it with angle if you do this drive in the future. With the angle you could mill down one of the sides down to like 1/4" so it wouldn't take up as much space, but shouldn't bend like flat bar will.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 27-04-2008, 13:02
FRC #1360
Mill lmao... Does a hacksaw work??
We actually may have milling capabilities next year (fingers crossed) so it will turn out better. We will also be sticking with this for the next couple of years (game dependant of course) to prefect it and call it our own. This years was more of a large scale functional prototype, next year has about a billion upgrades to it
Thanks for the comments!
pic: 1565 Twitch the missing Linkage Ball hold T3_1565 Extra Discussion 13 30-03-2008 14:00
pic: 1565 Twitch the missing Linkage Underbelly T3_1565 Robot Showcase 12 17-03-2008 13:58
pic: 1565 Linkage Drive System T3_1565 Extra Discussion 10 13-02-2008 15:44
pic: 1565 Extended Version T3_1565 Extra Discussion 5 04-02-2007 22:20
pic: 1565 Compact Version T3_1565 Extra Discussion 2 04-02-2007 20:37
