Go to Post You can sometimes step outside the box if you have properly thought through the question. - Jim Zondag [more]
Unread 27-04-2008, 20:43
Re: The 2009 Control System Q&A Thread
Originally Posted by dcbrown View Post
Q. The WPILIB functionality will include both LV and C libraries, but will exisiting NI LV libraries be converted into C libraries for team use also (such as aforementioned PID) or remain available in LV only? If C library form will eventually be available, is NI, FIRST, or WPI responsible for the conversion?
I'm not sure about across the board. From the beginning, we intended to have WPILIB and vision in both languages. For other libraries that are made available in LV, NI may be able to provide C versions if they exist, or wrappers to any underlying C code. But the word converted implies an automatic process, and in case it isn't clear, LV doesn't convert to C, so that isn't an option. Since the goal is really to have a nice parity and symmetry between C and LV, I think between NI, WPI, and the rest of the community, we will have a really nice set of libraries for both languages.
Q. When will the VxWorks C/C++ API as it currently exists (without FIRST/WPILIB add ons) on cRIO be released to FIRST teams from NI? For example, RPTs are not supported and there is a special driver/interface to the FPGA as an add on to VxWorks for the cRIO.
The toolchain can already be downloaded from WindRiver, as can a demo of LV from NI. C tools targetted for cRIO aren't currently a standard product, so I'm afraid that the first availability will be nearer to when the HW is available.
Greg McKaskle
Behind the Design 2009 AndyB General Forum 31 16-06-2008 13:59
Purchasing the 2009 controller Tottanka FRC Control System 60 04-05-2008 19:44
The Access Points on the 2009 Control System Shadow503 Rumor Mill 10 28-04-2008 23:22
Championship Event in Atlanta for 2007 = Confirmed (possibly 2008 & 2009 too) Elgin Clock Championship Event 18 24-08-2005 00:37
pic: The Bobcats 2001 & 2003 & Admirers CD47-Bot Robot Showcase 19 28-02-2004 12:36
