Go to Post The bottom line is, what works best for YOUR team is what the best solution is. - EricH [more]
Unread 27-04-2008, 15:32
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Future use of cRIO?
I believe that the cRIO is set to be reused every year for at least som set of years, so would that have any implications on the placement and build of the the robot, since it has its own requirements and we have to move it from robot to robot on testing and demos?
Unread 27-04-2008, 16:43
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Future use of cRIO?
I heard this too, but I think it is only a rumor.
Just as the deployment of the cRio to teams has not yet been finalized - I believe that the decision on whether or not to give one as mandatory in the kit has not yet been made.
I personally hope that they decide to make it mandatory since that might lower the cost for everyone.... and I think 90% of teams will want a new one each year.
but then again that means that teams that don't want it or even worse - can't afford it have to get one despite their objections.
but the counter-counter argument is that if it is mandatory then they can mass produce with certain numbers (+- the growth of FIRST) and thus lower the cost.
If it is a team choice then the numbers may vary wildly from year to year and they will have to produce in small numbers which is more costly.
Has getting a controller in the kit ever been a team's choice in the past?
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 27-04-2008, 17:19
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I went to the mentor's meeting (as I am a future mentor) of the new cRIO and control system in Atlanta on Thursday night. They mentioned that the cRIO will be more expensive than our current control system, but many of the parts in the cRIO are being donated by the vendors. They said at this point, teams should look at reusing their controller year after year, but they will have the cRIO available for purchase, you know... if for some reason your cRIO breaks or your team likes to keep your robots together year after year.
So basically... I believe they intend to "give" teams only one cRIO, and they can purchase additional ones as they like. So I believe you will reuse them year after year.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 27-04-2008, 17:33
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
RyanN is correct, their current plan is to give one controller to teams to be reused every year, while teams can buy an additional controller every year at an immensely reduced cost.
Unread 27-04-2008, 17:43
DGrohnke1023's Avatar
DGrohnke1023 DGrohnke1023 is offline
Is Looking Backward to Look Forward
AKA: The Dan
FRC #1023 (Bedford Express)
Team Role: Driver
DGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of light
With teams only getting 1 cRIO; in the years after 2009 will the price of the KOP be different for rookies and veterans?
Daniel Grohnke
2009 Bedford Express Captain
2009 - Lansing and Troy Districts, The Championship
2008 - GLR Quarterfinalist & MARC Semifinalist
2007 - GLR & Boilermaker Finalist & MARC Champion
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarterfinalist
2005 - GLR Finalist & Judges Award
2004 - GLR/DTR Semifinalist
2003 - GLR Quarterfinalist & GLR/NAT'L Rookie All Star
Unread 27-04-2008, 17:45
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
I had already stated that I was fairly certain about this part.
My question is how it will affect demos and build of robots.
Unread 27-04-2008, 17:52
It would mean that we'd have to keep programs around so that if there was a call for the 2009 robot in 2010, we'd pull the unit from 2010 and put in on 2009 with the 2009 code, then switch back.
I'm not so sure that's a wise move. Maybe all teams get two, then it's get your own would be better. Sometimes demos come up suddenly while the robot isn't there. Two would make sure that practice robots could be built, or old robots kept alive for another year for demo uses.
Unread 27-04-2008, 18:04
The pricing isn't finalized yet, so noone knows. But my guess is that NI will supply the cRIO in the '09 KOP at a huge expense on their part, and that future KOP money will offset that expense, meaning that the price would be the same.
Unread 27-04-2008, 23:17
RyanN's Avatar
RyanN
A modular system that can be swappable between all your robots sounds like it would be your best bet. Of course, you would have to reprogram it for each robot, which would take all of 2 seconds with your laptop right beside you. As more and more information become available, you can start designing a modular system.
My only question is... will all the other components be reused, or will they be provided new? If the cRIO isn't going to be given each year, what about the power distribution board or the I/O boards? If they are given out each year, then this will make a reusable system much easier to build, and a simple plug and unplug setup will work fine and will be reliable.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 28-04-2008, 04:33
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
I don't know about you guys but when 2010 comes around the corner I can tell you now that the 2009 controller isn't coming off of our robot!
It might be a bit expensive but come on.... unless the cRio costs significantly more than the current controller I think it is highly reasonable to purchase a new one each year.
a functional demo robot is almost worth it's weight in Dollar coins (in getting new students, mentors, parents and sponsors)!
That is much more than the price of a controller no matter how they price it....
-Leav
-Paraphrasing JFK
Unread 28-04-2008, 09:35
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Depending on how far you go with the cRio you could always install the IFI controller on the demo robot.
Unread 28-04-2008, 09:46
REVving up for a new season
FRC #2848 (All-sparks)
my issue with this stems from the fact that it means that the new controller will not be upgraded for years. I see this as FIRST getting into the same issues which pushed them away from IFI. Locking into a controller for multiple years while important for teams makes them majority supplier dependent. If it truly is the case that NI is only going to give one controller in the first year and then recycle them for financial reasons, I hate to see the year that NI is not doing well. Seems to me that this would indicate some hesitance in having the whole program on their backs financially.
I hate the idea of only getting one controller, as it raises many issues which teams don't currently have. As many would happen demo robots become difficult, helping pre-rookies at off-season events becomes impossible, and it puts a huge liability on teams breaking their controllers as most could not afford replacements (in the past 2 years teams could use older controllers if they needed to).
For lack of a better way to describe it this seems really cheap on behalf of NI and/or FIRST.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 28-04-2008, 10:11
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
How would you expect teams to break the controller?
Unread 28-04-2008, 10:20
Billfred's Avatar
Billfred Billfred is offline
Bad wiring and unexpected loads on the connections seem to be the two biggest killers of the IFI controllers. Both happen to a nonzero amount of teams every season in spite of their best efforts, rookies and veterans alike.
Unread 28-04-2008, 10:22
Dropping metal shavings in a sensitive spot.
Miswiring of power and consequent electrical fryage.
Accidentally drilling through it.
Fatal EMI induced by nearby arc welding.
Mechanical impact on a plug-in module.
Corruption of firmware.
Water damage.
Never underestimate the ability of a team of high school students and engineers to break expensive things.
Students build SEGWAY in 3 months using Labview and the cRIO neutrino15 Programming 31 27-04-2008 22:08
Which operating system do you use/want to use? neutrino15 Programming 17 12-01-2008 00:05
If you have to use dial-up, don't use NetZero JBotAlan Chit-Chat 7 18-12-2006 01:39
FIRST in FUTURE RoboMadi Chit-Chat 11 10-12-2006 18:23
Ethics 101: To re-use or not to re-use? aaeamdar General Forum 87 07-12-2006 19:10
