Go to Post thats like having 24 young men going wild for 2 minutes - thats how much power is available during a match. - KenWittlief [more]
Old 28-04-2008, 11:36
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: Quick question about 6wd!
Often on a 6WD, the center wheel is lowered anywhere from 1/8" to 1/4" depending on the amount of rock wanted. Because of this, the robot only hase contact with 4 wheels on the ground at a time, resulting in less friction on turns. If the COG is dead center, then the bot wants to stay on those 2 center wheels, which allows for the easy turning.
Another method to make them easy to manuver is putting omni wheels on the ends. (See 488's base from this year) This allows for the same traction as a rocker style 6wd, but the dropped center wheel is un-needed.
As for disadvantages, the only one I can think of is it can be heavy, but there are easy ways to fight this, such as using a 25 chain rather than a 35 chain.
Old 28-04-2008, 11:39
Brandon Holley's Avatar
Here is a classic case of search before you post! There are a bajillion threads on this topic...
However the quick answer you are looking for is that SOME (most?) 6WDs have a center wheel that is lowered more than the corner wheels. This essentially gives you 2 4WDs, but with the maneuverability of a very short wheel base.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Old 28-04-2008, 12:30
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
here are a few posts to help you out:
http://www.chiefdelphi.com/forums/sh...&highlight=6wd
Old 28-04-2008, 12:59
Billfred's Avatar
Billfred Billfred is offline
Given the prevalence of the Kitbot from over the past four years (which supports rock), and from my unscientific survey of folks who've rolled their own frames I'd move the needle towards "most".
Old 28-04-2008, 13:00
Yeah i concur with that statement as well...i didnt want to make a blanket statement
Old 28-04-2008, 14:19
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Personally I think using omni wheels on the corners is a bad idea and I strongly advise against it. As a driver, whether on offence or defence, if I know that you have omni wheels on ur corners I will use them to my advantage. They may make your robt easy to turn... but that just makes my job a whole lot easier. i just tap ur corner and you spin like a top. I can pretty much push you where ever I want and you can't do much to stop me.
From past experience the "rocker" is the best method of 6wd. if you can keep your CG rather constant (like not moving from front to back alot) you probabilly wont even notice a rock. Just be sure to keep the friction down on your corner wheels (i.e. only use 1" wheels if using high traction tread). This will still allow you to turn easily but give you enough traction so if pushed you still maintain control.
IMO...
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Old 28-04-2008, 14:27
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
IMO...
We are able to set up our robot, with encoders, to actively seek the last input state. If the robot wasn't turning and you try to spin it, it can automatically fight the rotation and hold its heading.
We don't usually run the robot that way -- it's not worth the headache of tweaking and tuning the PID values -- and we don't really have many problems with people spinning us around.
Different strokes for different folks.
--Madison--
...down at the Ozdust!
Unread 28-04-2008, 14:31
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
This works on 'normal' six wheel drive bots that have a dropped center as well. The way I look at it is this: If you build your robot so it's easy for you to turn, then it will be easy for others to turn you, too!
In 2007 our robot was the standard 6wd, dropped 1/8" center, 6" wheel drive train. When people played defense on us, they could turn us no problem.
In 2006, the best defensive bot I've ever seen (1662!) had four 8"x2" wheels, all at the corners. Their robot had quite a bit of trouble turning, but when they wanted to stay in place, they stayed in place.
It's just another one of those tradeoffs...
Unread 28-04-2008, 17:31
bigbeezy's Avatar
AKA: Bryan
That is true but i have found that the little bit of resistance that you have on the corners can go a long way. We had 8"x2" wheels on our bot in '07 and defenders had a hard time pushing us, but when it came time to turn it was nearly impossible, especially in high gear. I guess there is just a fine line between good turning and strength against defence. Granted alot has to do with the game as to how much defence will be played and how maneuverable you want to be.
Quick question about team standings Bochek General Forum 2 01-03-2008 10:51
Quick Question about team structure... The Mascot Team Organization 3 10-05-2007 11:53
quick question [about Halo ce]...... Devastater Chit-Chat 0 04-04-2005 20:15
Quick question about the ramp archiver 2001 1 23-06-2002 22:51
quick question about qualifying points Hymnson General Forum 4 25-09-2001 21:19
