Go to Post FIRST already has 494 Martians, plus 70 more. - GaryVoshol [more]
Unread 28-04-2008, 14:31
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Quick question about 6wd!
Originally Posted by bigbeezy View Post
Personally I think using omni wheels on the corners is a bad idea and I strongly advise against it. As a driver, whether on offence or defence, if I know that you have omni wheels on ur corners I will use them to my advantage. They may make your robt easy to turn... but that just makes my job a whole lot easier. i just tap ur corner and you spin like a top. I can pretty much push you where ever I want and you can't do much to stop me.
This works on 'normal' six wheel drive bots that have a dropped center as well. The way I look at it is this: If you build your robot so it's easy for you to turn, then it will be easy for others to turn you, too!
In 2007 our robot was the standard 6wd, dropped 1/8" center, 6" wheel drive train. When people played defense on us, they could turn us no problem.
In 2006, the best defensive bot I've ever seen (1662!) had four 8"x2" wheels, all at the corners. Their robot had quite a bit of trouble turning, but when they wanted to stay in place, they stayed in place.
It's just another one of those tradeoffs...
Unread 28-04-2008, 17:31
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
That is true but i have found that the little bit of resistance that you have on the corners can go a long way. We had 8"x2" wheels on our bot in '07 and defenders had a hard time pushing us, but when it came time to turn it was nearly impossible, especially in high gear. I guess there is just a fine line between good turning and strength against defence. Granted alot has to do with the game as to how much defence will be played and how maneuverable you want to be.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Quick question about team standings Bochek General Forum 2 01-03-2008 10:51
Quick Question about team structure... The Mascot Team Organization 3 10-05-2007 11:53
quick question [about Halo ce]...... Devastater Chit-Chat 0 04-04-2005 20:15
Quick question about the ramp archiver 2001 1 23-06-2002 22:51
quick question about qualifying points Hymnson General Forum 4 25-09-2001 21:19
