Go to Post Can you describe how you utilized your human head device on your intake? - Kevin Ainsworth [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 28-04-2008, 23:22
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
Re: The Access Points on the 2009 Control System
Hmm my take on this:
1. use smarter nodes for APs. Like those USD$30 fon/meraki devices.
Allows encryption, filtering, etc. We certainly do not want rogue data interrupting the matches.
2. UDP for control. All realtime control protocols use UDP.
(Whats UDP? Google )
3. QoS is necessary. Set control packets to highest priority, video stream to lowest, debug messaging medium, etc
4. Use various channels. There are approx 13 channels, of which some slightly interfere with each other. Now we approx have 54Mbps of capacity per channel. Designing the system to operate at a minimum of 11Mbps or lower would be good coz, in a case where a channel is saturated with colliding data from other networks on that channel, your system will likely to perform constantly. We can have 1 team using 1 channel per match, i.e. when 2 matches are going on simultaneously they would be using 8 channels.
| jamesyong.net |
FVC2007, FTC2008
Buying the 2009 control system BornaE FRC Control System 9 16-10-2008 17:16
NEW 2009 Control System Released qnetjoe FRC Control System 296 15-08-2008 15:02
2009 Control System Feature Wishlist tdlrali FRC Control System 47 17-06-2008 00:25
pic: 2009 Control System, Mounted Billfred FRC Control System 23 01-05-2008 19:02
2009 Control System Possibility? Racer26 Rumor Mill 121 25-04-2008 09:05
