Thread Tools |
Rating:
Display Modes |
Re: NEW 2009 Control System Released
However, given the choice (no price difference) I'd rather have the kernel that was built to be an RTOS rather than one that is converted to work like one. The cRIO is very expensive so I wouldn't recommend tinkering with your only cRIO (buy a really awesome desktop instead, its cheaper). If you want to tinker and install Linux on an embedded system, I highly recommend installing dd-wrt on a compatible router. It's low risk and you get some amazing features. |
Comparision of ports of VxWorks on PPC and RTLinux has shown key elements in terms of real time response favors VxWorks by 30-50%. RTLinux isn't a slouch, but does fall short in real time response in comparison.
This article comes to mind, but I remember reading a couple others: Performance Analysis of VxWorks and RTLinux. In general, even if you are not writing a bunch of ISRs for devices, the nature of data flow programming depends upon the deterministic response of handling hard clock interrupts in order to time slice all your tasks. Another issue is one of support. RTLinux would end up needing a grass roots support effort on this platform along with a port/creation of its own "WPILIB" equivalent. But the real heartache would come with the FPGA and having to integrate that into RTLinux. Just my opinion - it would be an interesting academic exercise, but you'd be fighting a huge uphill battle to get it adopted by more than a handful of teams because it doesn't provide significant differentiators in terms of functionality while at the same time having potential detrimental performance issues by comparison. |
I guess its a matter of choice one has to make, depending on their financial capabilities in using VxWorks or climbing the uphill task.
For those familiar with Linux, probably wouldn't mind taking a look at using RTLinux on it. As for the FPGA interface, no clue, but probably a kernel module for interfacing with it over the PCI bus has to be made if non currently exists. |
I know this is pretty much off-topic, but
I'm looking at my WRT54GL settings, and it supports 250MHz. I do agree that it has some amazing features, though I haven't tried the Samba share, SSH access, or hotspot settings. |
Not forgetting the undocumented TTL serial port on the circuit board. More possibilities there! Could do some justice to the Vex system
#7
I believe at this point this discussion deserves its own thread.
| Buying the 2009 control system | BornaE | FRC Control System | 9 | 16-10-2008 17:16 |
| 2009 Control System Feature Wishlist | tdlrali | FRC Control System | 47 | 17-06-2008 00:25 |
| pic: 2009 Control System, Mounted | Billfred | FRC Control System | 23 | 01-05-2008 19:02 |
| 2009 Control System Possibility? | Racer26 | Rumor Mill | 121 | 25-04-2008 09:05 |
| Forum Request: Post-2009 control system? | Billfred | CD Forum Support | 3 | 22-04-2008 16:22 |
