Go to Post It's too late to turn back - the only way is forward. Together - with a plan. - JaneYoung [more]
Unread 04-29-2008, 12:22 PM
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Best Drivetrain
I am posting this because a rookie team in Davis was having a hard time deciding and creating a drivetrain for their robot. There have been many different types of drivetrains used in FIRST. So in order to help all the rookie teams for nex year, what drivetrain has been the most dominant from the 2005 season and on?
-rc
ps Pictures please
R.C.
MadTown Robotics Team 1323
Unread 04-29-2008, 12:26 PM
Re: Best Drivetrain
I would say the KOP transmission with 2 CIM motors per side, driving six wheels via chains. More robots use this than all other layouts put together. My observation. YMMV. Offer not valid in Michigan.
Unread 04-29-2008, 12:29 PM
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Best Drivetrain
6 wheel drive with either lowered center wheels (~1/8") or omnis on the corners. This has without a doubt been the most successful drivetrain in the past and is very simple to build. As long as you can build a 4 wheel drive you can fairly easily add 2 more wheels. If you really want to improve it, add traction wheels such as ifi and a 2 speed transmission. An even better addition is directly driving the center wheels off the transmission shaft so that even if all of the chains break the robot will still be powered. This requires a little bit more work though and most likely precise machining capabilities.
Mentor 2415
Unread 04-29-2008, 12:32 PM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Best Drivetrain
Specifically, it requires a longer output shaft than any standard transmission will give you.
Usually it's just as much weight to do the bearing blocks for a direct drive setup as it is to do an AM hub with AM flat sprockets with extra chains. Since it's more difficult to do the former, most teams stick with the default method.
GitHub
Unread 04-29-2008, 12:34 PM
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Re: Best Drivetrain
If they are rookies, BUILD A SIMPLE DRIVETRAIN. Overly complicated systems have killed rookies and vets alike. Our best best years came from simple 6 wheel "rockers" that were very quick and easy to fix. Your programmers will also thank you.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 04-29-2008, 12:37 PM
Re: Best Drivetrain
My old FRC team has never built a really great robot (sad, but true), but their chain-driven, 6WD chassis with the KOP gearbox has been bulletproof all four of the last seasons. The concerns about breaking #35 chain (in my experience) are exaggerated -- if you don't do anything weird or stupid, they simply won't break before the motors stall out. When you start getting into more exotic choices, stuff starts breaking. It might be worth it if you have a sophisticated robot and build process, but I think most teams would be well-advised to go with a proven drive-train and spend their brain cells on building better game mechanisms.
Unread 04-29-2008, 12:40 PM
AKA: Sean
Re: Best Drivetrain
Direct drive does require modifiying all but the andymark super shifters. Although getting a longer shaft machined is really not that difficult. My preference for direct drive is that even if all chains somehow snap, the robot will still perform just as well since the center wheels are always in contact with the ground. This also makes it slightly more reassuring to use #25 chain since no matter how many chains break the robot will still run. #25 chain saves a ton of weight over #35 and it also only uses 4 chains versus at least 6 in a normal 6 wheel drivetrain. The only thing to remember with #25 and really even #35 chain is to have a way to easily tension the chain. If you can keep the chain tensioned and lined up properly then you will never break a #25 chain.
Mentor 2415
Unread 04-29-2008, 12:45 PM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Best Drivetrain
-rc
ps Pictures please
2007 Super-Rookies - 2056 Patriotics
6wd built on a kit-frame. Winners of Waterloo, GTR, and IRI that year.
http://www.oppatriotics.com/pic_0139.html
I wish there was a simple way to convince every rookie team to go this route and have their drivebase complete by 2nd week of build.
Actually, there are times when I wish I could convince veteran teams to do this too =).
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 04-29-2008, 12:52 PM
EricH EricH is online now
Re: Best Drivetrain
Sorry, guys, but you are ALL wrong.
The correct answer is: we don't know.
The game hasn't been released yet. Maneuverability might be key, power might be key. We don't know. We won't know until January.
That said: Rookies should NOT attempt a swerve or holonomic. Even veterans have trouble with those sometimes.
4WD or 6WD skid steer, Kit frame, would be my best advice. Those are really versatile, especially the 6WD drop center. Kit trannies would be recommended, but I'd have to see the game before committing to anything. Exactly what setup depends on the game. Chain drive, due to ease of use. Because this is a rookie team, tensioner of a block of delrin under or over the chain mounted so the chain digs into it a little. While it is possible to get away with not using a tensioner, that's something that only a veteran team or a team with decent CAD/manufacturing ability should attempt.
Unread 04-29-2008, 12:53 PM
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Best Drivetrain
FIRST Champions:
2005:
330- 6WD, higher traction center wheel (possibly dropped)
67- Swerve
503- 2WD w/ omnis (correct me if I'm wrong)
2006:
296- 2WD w/ casters
217- 6WD, lowered center wheel
522- Treads
2007:
190- 6WD, lowered center
987- 6WD, lowered center
177- 6WD, lowered center
2008:
1114- 6WD, lowered center wheel
148- Swerve drive
correct me if any are incorrect
Unread 04-29-2008, 12:54 PM
Re: Best Drivetrain
Originally Posted by Lil' Lavery View Post
FIRST Champions:
2005:
Dropped is definite. (It's also variable drop, if you play with it--the center wheel was pneumatic.)
Unread 04-29-2008, 01:00 PM
Billfred's Avatar
Billfred Billfred is offline
Re: Best Drivetrain
The most dominant drivetrains have a few common attributes:
1) The drivers are comfortable with the robot. This usually means it's a drivetrain they can build early in build season (or can build a spare of for practice easily enough).
2) Reliability. Robots that throw chains and don't turn don't fare that well. That applies for the long haul, too--1251, a dominant force in the regular season last year, had to sit out the elimination rounds at Mission Mayhem because they kept having troubles.
3) Quickness at the task at hand. The drivetrains that can get a given job done fastest tend to do better. That doesn't always mean raw speed--71 shuffled its way to a world title in 2002 going awful slow while ensuring that all three of the goals that season would get to their zone.
In my experience, this usually entails some flavor of 6WD. Some teams have reached a level of sophistication where they can go with more advanced drivetrains (see also: 148's coaxial swerve this season), but most of us are still where 6WD is the way to go for most cases.
Unread 04-29-2008, 01:10 PM
CraigHickman
Posts: n/a
Re: Best Drivetrain
What Billfred said.
Also, a couple questions so I can clarify my answer for you:
1. How advanced of machining do they have access to?
2. Do they want to rely on the kit?
3. How fast do you want to move? (fast, slow, push anything, etc)
4. Are you looking for a lightweight system, or something that's an absolute beast?
Unread 04-29-2008, 01:28 PM
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Best Drivetrain
My $0.02:
For a rookie stick with a #35 chain drive. Its far more forgiving than #25. The weight savings isn't worth the tolerance hassles or the effort to get sprockets that aren't from the KOP.
If the point of asking the question is to save labor so the rookies can focus on other mechanisms then the kitbot is the best way to go. It works and is solidly reliable and doesn't take long to build freeing your team to focus on make other parts for the robot, isn't that why we got the kitbot in 2005?
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 04-29-2008, 01:39 PM
CraigHickman
Posts: n/a
Re: Best Drivetrain
Originally Posted by Peter Matteson View Post
My $0.02:
ARGH! I hate to be a bit aggravated in my response, but NO NO NO! If you don't have a rookie team start experimenting now with a newer system, how will they ever get to it?! Why are we discouraging innovation and trying new things?! Isn't that counter to EVERYTHING FIRST is about?!
Besides, #25 chain is more than strong enough, provided it's done correctly! Here's what I mean by correctly, so I'll have a post to link people to every time this nonsense comes up: It needs to have the sprockets perfectly co-planar. The chain needs to be properly tensioned (not too tight, not too loose). That's ALL! I've used #25 for 4 years now and NEVER had a failure, and that's for both arms AND drivetrains!
Another point: We all have NO idea what the Kitbot is going to be, NONE of us do! It hasn't been built yet, so we don't know what kind of chains, if any, will be on it. Let's please save from making generalizations about a system that hasn't been delivered yet.
I apologize for the outburst, but I HATE the myth that #25 is "too weak" or "too hard" for FIRST use. So please, OP, whatever you build, save yourself the 5ish pounds, and use #25!
drivetrain!!! hiimcristhian General Forum 3 01-12-2008 11:51 PM
Drivetrain Kit Justin Brooks Robotics Education and Curriculum 9 01-27-2007 04:11 PM
Best Matches (best fought not score) ne0x0n General Forum 13 04-01-2005 12:40 PM
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 01-10-2003 05:22 PM
Drivetrain Hawk135 Technical Discussion 3 01-06-2003 10:14 PM
