Go to Post Imagination is important, but try not to use it as a substitute for actual information. - Alan Anderson [more]
  #36   Spotlight this post!
Unread 29-04-2008, 13:45
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: Best Drivetrain
If you want the easiest drive system to build do what we did;
have the boxes output be gear, have the wheel shaft have a gear, have the gear on the box directly attach to the shaft that said wheel is on... one box 2 CIMs per side, two drive wheels per side, have your front be skids (literally no work what so ever)... very simple tank drive...
Is now an engineer thanks to FIRST.
drivetrain!!! hiimcristhian General Forum 3 12-01-2008 23:51
Drivetrain Kit Justin Brooks Robotics Education and Curriculum 9 27-01-2007 16:11
Best Matches (best fought not score) ne0x0n General Forum 13 01-04-2005 12:40
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Drivetrain Hawk135 Technical Discussion 3 06-01-2003 22:14
