Go to Post At the competitions you can look like an idiot and nobody cares, that makes me happy... - Laura 1547 [more]
Unread 29-04-2008, 21:05
EricH EricH is online now
Re: Best Drivetrain
Originally Posted by Lowfategg View Post
On our FTC bot this year the CG was a little bit forwards of the rear wheels so it worked well. My guess is if we did an FRC bot next year we would go with a six wheel drive system using omni wheels on outside with traction wheels in the center. Just on another note whats the best kind of omnidirectional drive in the real world and not just looking a pros and cons of the designs of each.
OK, that might work. Don't go with a "rocker" system if you do, though. That's too much maneuverability.
Actually, I just remembered. 494 did this a few years ago...
Corner omnis. The idea is a 4WD with the traction wheels on, say, left front and right rear. The other slots are omnis. Apparently it works pretty well.
Omnidirectional drive is the holonomic/mecanum/crab/swerve drives. The best type depends on the game.
Mecanum: 4WD with specialized programming and each wheel independently powered. Oh, and mecanum wheels.
Omni: 3-6 omni wheels arranged so that you can slide. It's a little trickier than mecanum.
Crab/swerve: each wheel turns. 3-4 wheels.
drivetrain!!! hiimcristhian General Forum 3 12-01-2008 23:51
Drivetrain Kit Justin Brooks Robotics Education and Curriculum 9 27-01-2007 16:11
Best Matches (best fought not score) ne0x0n General Forum 13 01-04-2005 12:40
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Drivetrain Hawk135 Technical Discussion 3 06-01-2003 22:14
