#16
Re: hey got a tech question about AM Trannys
And yeah, we tried stronger pins, but then the next weakest thing broke- the bearing the the pin holds against X= |
#17
We actually ran into the pin issue at NYC. The robot shifted for the better part of two competitions before finally shearing a roll pin in our last qualification match. We are currently looking into replacing the roll pin with a hardened dowel pin to give it some strength. Be careful doing something like this though, because the shaft is so small at the hole's location. You need to make sure you won't damage(via shifting not installation) the shaft changing to a dowel pin. At the competition we would have normally just changed the air pressure but it was needed for other parts of the robot.
#18
Are any of you limiting the piston stroke to ensure that the piston isn't shoving the dog into either dogged gear?
I have never worked closely with the AM trannys but on our own gearboxes we pay very close attention to the side load that the dog puts on the gear, making sure there is a gap of some sort so that the dog doesnt physically push on the dogged gears when the dog teeth are engaged. We use 1/4" ID nylon spacers to limit the pistons stroke to just under the distance required to move from being fully engaged in one gear to being fully engaged in the other. I should note, we run at a full 60 psi and use a #3-48 stainless SHCS instead (which is MUCH weaker than the included roll pin) We have yet to break a screw under normal conditions. A few times we failed to tighten the jam nut on the piston rod which allowed the dog to push on the dogged gear, and only during those few times did we have any problems. Couldn't hurt to throw it out there... Edit: Oops... I didn't even see Tyler's post. This just reaffirms what he said though! Last edited by Travis Covington : 29-04-2008 at 17:57. |
#19
In 2006 we shifted at 20 PSI just fine.
#20
This was with the SY3000 series SMC valves. The festo may perform differently though?
#21
With the AM's this year just above 10 psi still shifted gear perfectly fine. It started to get hairy anywhere under that.
#22
whenever we boot up the robot from a no-air state, it takes a noticeable amount of pressure before any of the solenoids will trip. i believe this is at about 20-30psi, so ?? |
#23
On the AM Servo Shifter page, these gear reductions are listed: Gear Reduction Low: 10.67:1 High: 4.17:1 Difference between Low and High: 2.56:1 Here is my description on how to "do the math", in a nutshell: A CIM motor has a free speed of about 5200. If two CIM motors are installed on an AndyMark gearbox, then the top speed (motor rpm) that you will be able to get is about 4300 or 4400. Let's call this the "top working speed". (The difference between the free speed and this working speed is because of efficiency losses, inertia, and friction in the mechanical system) Using 4400 rpm as this top working speed, here are the resulting low and high speeds for an AM Shifter (servo or pneumatic): Low: 412 rpm (4400 / 10.67) High: 1055 rpm (4400 / 4.17) This is the output rpm at the sprockets on the AM Shifter. Further reduction can be made, of course, with the sprockets on the wheels and the size of the wheel. Keep in mind that the smaller your wheel is, the less reduction you need to go an optimal speed. Now... regarding the roll pins shearing and other stuff, I will make another post. Tyler's post is right on the money. However, the Super Shifter did see more vibration this year than the AM Shifters experience. The AM Shifters all use chain drive. The Super Shifters can be used in direct drive situations. Because of this, the Super Shifters experience more vibrational loading. Like previously noted by Tyler and Travis, you must use stops on the cylinder so that the dog is positioned into place and held there, as opposed to continually pushing the dog into the gear. For servo shifting, this burns up the servo. For pneumatic shifting, this wears down roll pins. Also, shifting at 40 psi seems to work the same as 60 psi. I do not suggest using 25 psi unless you are only shifting when not pushing against anyone. Also, servo shifting does not work when pushing against anyone. Servo shifting pushes with about 5 pounds of force. Pneumatic shifting at 60 psi puts out 33 lbs of force. Regulating the pressure down to 40 psi still gives 22 pounds of shifting force. This is still much stronger and more responsive than servo shifting. Once again, I will say that I DO NOT RECOMMEND servo shifting, unless a team has absolutely no need for pneumatics on their robot. We have some improvements listed for these gearboxes: gearing options - other ratios (Toughbox, Stackerbox, maybe Shifters) adding an encoder to the Toughbox and AM Shifter higher strength roll pins Longer output shaft for Toughbox A better way to servo shift Optional aluminum side plates for AM Shifters These are in order of importance and priority. There may be more. We have a "to do" list on our main whiteboard at AndyMark central that is about 50 items long. I hope this helps. Sincerely, Andy |
#24
Back to the roll pin topic, I believe we broke the initial pins in both of this year's AM shifters before shipping the bot. We never broke pins in any of the AM shifters we used in the prior 2 years. We replaced with higher strength pins and didn't have any more problems. I know 1503 broke their pin at FLR and used our stronger pins to replace (dont know how that worked out past FLR). Maybe a lower quality batch of pins this year or just too much shifting into Overdrive. Last edited by The Lucas : 29-04-2008 at 22:36. |
#25
After FLR and using the stronger roll pin, 1503 didn't have any problems. A mistake we had made in our pneumatics was also corrected. We isolated the air control to the shifter (it had been tied into another sytem) so that we could have independent control of the pressure. And thanks to MOE's recommendation we also purchased the installation tool needed to install the roll pin in place without having to take the gearbox apart. We haven't had the chance to practice this one yet, but it will be one of our off-season drills.
#26
We love the supershifters! (just ordered two more). 25-30 psi, 3/4'' bore
by 1/2'' stroke(no spacers) cyl. and you will be fine for regionals and a few off-season. |
| hey, stupid question but... | fallen751 | Programming | 16 | 24-01-2007 17:49 |
| Got an question on start postion of the robot? | DanTheRobotMan | Rules/Strategy | 9 | 12-01-2006 17:32 |
| Tech Question About CAD and RP | indieFan | Chit-Chat | 2 | 23-07-2004 12:35 |
| Hey guys I got the Best Idea | Dima | Rules/Strategy | 18 | 20-01-2003 19:52 |
