Go to Post Eventually, the "less effective" tweaks will settle to the bottom, and the more effective ones will be assimilated by the group. Then someone will tweak the tweak. That's when the fun begins. - Billfred [more]
Unread 29-04-2008, 22:33
Re: Future use of cRIO?
Originally Posted by RyanN View Post
Also to touch into the ruggedness of the system... I'm very satisfied to say that I doubt many teams will be able to destroy their system apart from ripping a port out. The cRIO is very heavy, and I was astounded by the weight when I first picked it up in Atlanta. I believe the controller's casing is cast iron with a thick powder coat of paint on the outside. I'm not sure if the metal case is necessary, but it will make it much harder for teams to drill through or jigsaw in half.
I thought they said it was SLS. That can be metal, can be nylon. The pictures I've seen indicate something resembling the latter. I'd say most of the weight is internals.
SLS is pretty hard to damage without a tool...
Students build SEGWAY in 3 months using Labview and the cRIO neutrino15 Programming 31 27-04-2008 22:08
Which operating system do you use/want to use? neutrino15 Programming 17 12-01-2008 00:05
If you have to use dial-up, don't use NetZero JBotAlan Chit-Chat 7 18-12-2006 01:39
FIRST in FUTURE RoboMadi Chit-Chat 11 10-12-2006 18:23
Ethics 101: To re-use or not to re-use? aaeamdar General Forum 87 07-12-2006 19:10
