Re: 2002 CIM specs
Jeff-
We used to wire EDM a profile that would fit onto the "spline" in order to install a gear on that shaft. That would not take up too much space. Ken |
Re: 2002 CIM specs
Has anyone tried turning down the shaft and putting a keyway or flat on it? Would it even be possible or practical?
Re: 2002 CIM specs
You could machine the bore of your gear/hub/etc to fit over the OD of the CIM gear shaft, then drill a transverse hole through both pin them together.
Re: 2002 CIM specs
After we disassembled our 2002 robot, I took the 2002 cims and installed them into 2005 kitbot gearboxes. It was the square aluminum gearbox that looked sort of like the AM toughbox. I just slipped the gear over the shaft and tightened the set screw into the gear teeth. We only used them on a prototype drive train for programmers, so it did not see a lot abuse.
Re: 2002 CIM specs
Jeff,
Joe Johnson posted this in http://www.chiefdelphi.com/forums/sh...ghlight=atwood Quote:
| AndyMark CIM Planetary Gearbox Torque Specs Needed | KTorak | Technical Discussion | 4 | 17-01-2008 18:53 |
| Large CIM specs? | Xarda | Motors | 1 | 31-01-2007 23:07 |
| Small CIM Gear Specs | Joe_Widen | Technical Discussion | 2 | 03-04-2006 23:10 |
| Large CIM motor specs | ryan_f | Motors | 4 | 13-01-2006 21:38 |
| Drill and CIM specs | BlacKnight6604 | Motors | 1 | 13-01-2004 09:52 |
